Problem with installation of Thread / OpenThread Border Router and SLZB-MR3
i want to install “Thread” on my Home Assistant and unfortunately get an error message from the OpenThread Border Router.
My hardware is the SLZB-MR3. In this Hardware is “Matter over Thread” enabled in Radio 1 mode [EFR32MG24]. The SLZB-MR3 is connected via LAN and USB, with “Ethernet connection” enabled as the “connection mode”. I’ve also tried using USB, but without success.
The following messages appear in the OpenThread Border Router log.
What am I doing wrong?
What does the error message mean?
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service otbr-agent-rest-discovery: stopping
s6-rc: info: service otbr-agent-rest-discovery successfully stopped
s6-rc: info: service otbr-agent-configure: stopping
s6-rc: info: service otbr-agent-configure successfully stopped
s6-rc: info: service otbr-agent: stopping
00:11:50.739 [N] Mle-----------: Role leader -> detached
00:11:50.739 [N] Mle-----------: Role detached -> disabled
[22:44:53] INFO: otbr-agent exited with code 0 (by signal 0).
Chain OTBR_FORWARD_INGRESS (0 references)
target     prot opt source               destination
DROP       all  --  anywhere             anywhere             PKTTYPE = unicast
DROP       all  --  anywhere             anywhere             match-set otbr-ingress-deny-src src
ACCEPT     all  --  anywhere             anywhere             match-set otbr-ingress-allow-dst dst
otbr-ingress-deny-src-swap
otbr-ingress-allow-dst-swap
Chain OTBR_FORWARD_EGRESS (0 references)
[22:44:53] INFO: OTBR firewall teardown completed.
s6-rc: info: service otbr-agent successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service universal-silabs-flasher: stopping
s6-rc: info: service socat-otbr-tcp: stopping
s6-rc: info: service mdns: stopping
2025/07/23 22:44:53 socat[79] W exiting on signal 15
s6-rc: info: service universal-silabs-flasher successfully stopped
Default: mDNSResponder (Engineering Build) (Jan 14 2025 21:04:03) stopping
s6-rc: info: service banner: stopping
s6-rc: info: service socat-otbr-tcp successfully stopped
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[22:44:53] INFO: mDNS ended with exit code 4 (signal 0)...
s6-rc: info: service mdns successfully stopped
[22:49:22] INFO: The otbr-web is disabled.
[22:49:22] INFO: Enabled socat-otbr-tcp.
s6-rc: info: service socat-otbr-tcp: starting
s6-rc: info: service mdns: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service mdns successfully started
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service banner: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
[22:49:22] INFO: Starting mDNS Responder...
Default: mDNSResponder (Engineering Build) (Jan 14 2025 21:04:03) starting
[22:49:22] INFO: Starting socat TCP client for OTBR daemon...
 Add-on: OpenThread Border Router
 OpenThread Border Router add-on
 Add-on version: 2.13.0
 You are running the latest version of this add-on.
s6-rc: info: service socat-otbr-tcp successfully started
 System: Home Assistant OS 16.0  (amd64 / generic-x86-64)
 Home Assistant Core: 2025.7.3
 Home Assistant Supervisor: 2025.07.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[22:49:23] INFO: Flashing firmware is disabled
s6-rc: info: service universal-silabs-flasher successfully started
s6-rc: info: service otbr-agent: starting
[22:49:23] INFO: Setup OTBR firewall...
[22:49:23] INFO: Starting otbr-agent...
[NOTE]-AGENT---: Running 0.3.0-b067e5ac-dirty
[NOTE]-AGENT---: Thread version: 1.3.0
[NOTE]-AGENT---: Thread interface: wpan0
tiocmbic: Inappropriate ioctl for device
[NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///tmp/ttyOTBR?uart-baudrate=460800&uart-init-deassert
[NOTE]-AGENT---: Radio URL: trel://eno1
[NOTE]-ILS-----: Infra link selected: eno1
49d.17:59:21.872 [C] P-SpinelDrive-: Software reset co-processor successfully
49d.17:59:21.928 [C] P-RadioSpinel-: RCP => [C] Platform------: Reset info: 0x3 (EXT)
49d.17:59:21.928 [C] P-RadioSpinel-: RCP => [C] Platform------: Extended Reset info: 0x301 (PIN)
00:00:00.110 [N] RoutingManager: No valid /48 BR ULA prefix found in settings, generating new one
00:00:00.117 [N] RoutingManager: BR ULA prefix: fd6e:a0a7:f770::/48 (generated)
00:00:00.117 [N] RoutingManager: Local on-link prefix: fdde:ad00:beef:cafe::/64
00:00:00.143 [W] P-Netif-------: Failed to process request#2: No such process
s6-rc: info: service otbr-agent successfully started
s6-rc: info: service otbr-agent-configure: starting
Done
s6-rc: info: service otbr-agent-configure successfully started
s6-rc: info: service otbr-agent-rest-discovery: starting
00:00:00.541 [W] P-Daemon------: Daemon read: Connection reset by peer
[22:49:24] INFO: Successfully sent discovery information to Home Assistant.
s6-rc: info: service otbr-agent-rest-discovery successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
00:00:01.244 [N] RoutingManager: Local on-link prefix: fddd:a2b6:47a6:9581::/64
00:00:01.266 [N] Mle-----------: Role disabled -> detached
00:00:01.290 [N] P-Netif-------: Changing interface state to up.
00:00:01.314 [W] P-Netif-------: Failed to process request#5: No such process
00:00:01.719 [N] Mle-----------: Attach attempt 1, AnyPartition reattaching with Active Dataset
00:00:08.219 [N] RouterTable---: Allocate router id 52
00:00:08.219 [N] Mle-----------: RLOC16 fffe -> d000
00:00:08.230 [N] Mle-----------: Role detached -> leader
00:00:08.230 [N] Mle-----------: Partition ID 0x1f631c16
[NOTE]-BBA-----: BackboneAgent: Backbone Router becomes Primary!
00:00:09.655 [W] DuaManager----: Failed to perform next registration: NotFound
What error message?
I still can’t add Matter devices.
Zigbee works without problems via port :7638
(and chip CC2674P10 ) with this stick.
When I try to add a Matter device via the Android app under “Devices and Services,” I get the message
“Matter is currently unavailable.”
Under “Add-ons,” “Matter Server,” “Protocol” is now show an error?
“2025-07-30 17:52:40.039 (Dummy-2) CHIP_ERROR [chip.native.DIS] Failed to advertise records: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachable”
Here is a part of the protocol (this error comes almost at the end of this protocol) :
2025-07-30 16:36:19.612 (MainThread) INFO [aiorun] Closing the loop.
2025-07-30 16:36:19.612 (MainThread) INFO [aiorun] Leaving. Bye!
[14:36:19] INFO: matter-server service exited with code 0 (by signal 0).
s6-rc: info: service matter-server successfully stopped
 Add-on: Matter Server
 Matter WebSocket Server for Home Assistant Matter support.
 Add-on version: 8.0.0
 Home Assistant Core: 2025.7.4
 Home Assistant Supervisor: 2025.07.2
s6-rc: info: service matter-server: starting
s6-rc: info: service matter-server successfully started
[16:36:57] INFO: Starting Matter Server...
[16:36:58] INFO: Using 'eno1' as primary network interface.
[16:36:58] INFO: Successfully send discovery information to Home Assistant.
2025-07-30 16:37:00.149 (MainThread) INFO [matter_server.server.stack] Initializing CHIP/Matter Logging...
2025-07-30 16:37:00.150 (MainThread) INFO [matter_server.server.stack] Initializing CHIP/Matter Controller Stack...
[1753886220.173320][117:117] CHIP:CTL: Setting attestation nonce to random value
[1753886220.173539][117:117] CHIP:CTL: Setting CSR nonce to random value
[1753886220.174235][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1753886220.180791][117:117] CHIP:DL: Wrote settings to /tmp/chip_kvs
[1753886220.181072][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_factory.ini
[1753886220.182479][117:117] CHIP:DL: Wrote settings to /data/chip_factory.ini
[1753886220.182526][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_config.ini
[1753886220.183899][117:117] CHIP:DL: Wrote settings to /data/chip_config.ini
[1753886220.183923][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_counters.ini
[1753886220.185179][117:117] CHIP:DL: Wrote settings to /data/chip_counters.ini
[1753886220.186896][117:117] CHIP:DL: Wrote settings to /data/chip_factory.ini
[1753886220.186906][117:117] CHIP:DL: NVS set: chip-factory/unique-id = "50FDD8B3F3818942"
[1753886220.188271][117:117] CHIP:DL: Wrote settings to /data/chip_factory.ini
[1753886220.188283][117:117] CHIP:DL: NVS set: chip-factory/vendor-id = 65521 (0xFFF1)
[1753886220.190109][117:117] CHIP:DL: Wrote settings to /data/chip_factory.ini
[1753886220.190121][117:117] CHIP:DL: NVS set: chip-factory/product-id = 32769 (0x8001)
[1753886220.201088][117:117] CHIP:DL: Wrote settings to /data/chip_counters.ini
[1753886220.201121][117:117] CHIP:DL: NVS set: chip-counters/reboot-count = 1 (0x1)
[1753886220.202834][117:117] CHIP:DL: Wrote settings to /data/chip_counters.ini
[1753886220.202863][117:117] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1753886220.204791][117:117] CHIP:DL: Wrote settings to /data/chip_counters.ini
[1753886220.204819][117:117] CHIP:DL: NVS set: chip-counters/boot-reason = 0 (0x0)
[1753886220.206430][117:117] CHIP:DL: Wrote settings to /data/chip_config.ini
[1753886220.206455][117:117] CHIP:DL: NVS set: chip-config/regulatory-location = 0 (0x0)
[1753886220.208080][117:117] CHIP:DL: Wrote settings to /data/chip_config.ini
[1753886220.208106][117:117] CHIP:DL: NVS set: chip-config/location-capability = 2 (0x2)
[1753886220.208556][117:117] CHIP:DL: Got Ethernet interface: eno1
[1753886220.208913][117:117] CHIP:DL: Found the primary Ethernet interface:eno1
[1753886220.209254][117:117] CHIP:DL: Got WiFi interface: wlp58s0
[1753886220.209287][117:117] CHIP:DL: Failed to reset WiFi statistic counts
2025-07-30 16:37:00.209 (MainThread) INFO [chip.storage] Initializing persistent storage from file: /data/chip.json
2025-07-30 16:37:00.210 (MainThread) ERROR [chip.storage] [Errno 2] No such file or directory: '/data/chip.json'
2025-07-30 16:37:00.210 (MainThread) CRITICAL [chip.storage] Could not load configuration from /data/chip.json - resetting configuration...
2025-07-30 16:37:00.210 (MainThread) WARNING [chip.storage] No valid SDK configuration present - clearing out configuration
2025-07-30 16:37:00.210 (MainThread) WARNING [chip.storage] No valid REPL configuration present - clearing out configuration
2025-07-30 16:37:00.290 (MainThread) INFO [chip.CertificateAuthority] Loading certificate authorities from storage...
2025-07-30 16:37:00.290 (MainThread) INFO [chip.CertificateAuthority] New CertificateAuthority at index 1
2025-07-30 16:37:00.293 (MainThread) INFO [chip.FabricAdmin] New FabricAdmin: FabricId: 0x0000000000000002, VendorId = 0x134B
2025-07-30 16:37:00.293 (MainThread) INFO [matter_server.server.stack] CHIP Controller Stack initialized.
2025-07-30 16:37:00.294 (MainThread) INFO [matter_server.server.server] Starting the Matter Server...
2025-07-30 16:37:00.296 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetching the latest PAA root certificates from DCL.
2025-07-30 16:37:03.205 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetched 69 PAA root certificates from DCL.
2025-07-30 16:37:03.206 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetching the latest PAA root certificates from Git.
2025-07-30 16:37:03.525 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetched 2 PAA root certificates from Git.
2025-07-30 16:37:03.527 (MainThread) INFO [chip.FabricAdmin] Allocating new controller with CaIndex: 1, FabricId: 0x0000000000000002, NodeId: 0x000000000001B669, CatTags: []
2025-07-30 16:37:03.583 (Dummy-2) CHIP_ERROR [chip.native.DIS] Failed to advertise records: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachable
2025-07-30 16:37:03.593 (MainThread) INFO [matter_server.server.vendor_info] Loading vendor info from storage.
2025-07-30 16:37:03.593 (MainThread) INFO [matter_server.server.vendor_info] Loaded 0 vendors from storage.
2025-07-30 16:37:03.593 (MainThread) INFO [matter_server.server.vendor_info] Fetching the latest vendor info from DCL.
2025-07-30 16:37:03.873 (MainThread) INFO [matter_server.server.vendor_info] Fetched 336 vendors from DCL.
2025-07-30 16:37:03.873 (MainThread) INFO [matter_server.server.vendor_info] Saving vendor info to storage.
2025-07-30 16:37:03.882 (MainThread) INFO [matter_server.server.device_controller] Loaded 0 nodes from stored configuration
2025-07-30 16:37:03.891 (MainThread) INFO [matter_server.server.server] Matter Server successfully initialized.
s6-rc: info: service matter-server: stopping
2025-07-30 16:37:05.714 (MainThread) WARNING [aiorun] Stopping the loop
2025-07-30 16:37:05.715 (MainThread) INFO [aiorun] Entering shutdown phase.
2025-07-30 16:37:05.715 (MainThread) INFO [aiorun] Executing provided shutdown_callback.
2025-07-30 16:37:05.715 (MainThread) INFO [matter_server.server.server] Stopping the Matter Server...
2025-07-30 16:37:05.721 (MainThread) INFO [matter_server.server.stack] Shutting down the Matter stack...
2025-07-30 16:37:05.721 (MainThread) CHIP_ERROR [chip.native.CTL] Shutting down the stack...
2025-07-30 16:37:05.723 (MainThread) CHIP_ERROR [chip.native.DIS] Failed to advertise records: src/inet/UDPEndPointImplSockets.cpp:421: OS Error 0x02000065: Network is unreachable
2025-07-30 16:37:05.728 (MainThread) INFO [aiorun] Waiting for executor shutdown.
2025-07-30 16:37:05.728 (MainThread) INFO [aiorun] Shutting down async generators
2025-07-30 16:37:05.728 (MainThread) INFO [aiorun] Closing the loop.
2025-07-30 16:37:05.729 (MainThread) INFO [aiorun] Leaving. Bye!
[14:37:05] INFO: matter-server service exited with code 0 (by signal 0).
[17:52:34] INFO: Starting Matter Server...
[17:52:34] INFO: Using 'eno1' as primary network interface.
[17:52:34] INFO: Successfully send discovery information to Home Assistant.
2025-07-30 17:52:36.506 (MainThread) INFO [matter_server.server.stack] Initializing CHIP/Matter Logging...
2025-07-30 17:52:36.506 (MainThread) INFO [matter_server.server.stack] Initializing CHIP/Matter Controller Stack...
[1753890756.529373][117:117] CHIP:CTL: Setting attestation nonce to random value
[1753890756.529612][117:117] CHIP:CTL: Setting CSR nonce to random value
[1753890756.530346][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1753890756.536877][117:117] CHIP:DL: Wrote settings to /tmp/chip_kvs
[1753890756.537120][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_factory.ini
[1753890756.538249][117:117] CHIP:DL: Wrote settings to /data/chip_factory.ini
[1753890756.538275][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_config.ini
[1753890756.539323][117:117] CHIP:DL: Wrote settings to /data/chip_config.ini
[1753890756.539353][117:117] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /data/chip_counters.ini
[1753890756.540811][117:117] CHIP:DL: Wrote settings to /data/chip_counters.ini
[1753890756.542466][117:117] CHIP:DL: Wrote settings to /data/chip_factory.ini
[1753890756.542477][117:117] CHIP:DL: NVS set: chip-factory/unique-id = "9E5D1D21FAD6ED05"
[1753890756.544073][117:117] CHIP:DL: Wrote settings to /data/chip_factory.ini
[1753890756.544085][117:117] CHIP:DL: NVS set: chip-factory/vendor-id = 65521 (0xFFF1)
[1753890756.545697][117:117] CHIP:DL: Wrote settings to /data/chip_factory.ini
[1753890756.545710][117:117] CHIP:DL: NVS set: chip-factory/product-id = 32769 (0x8001)
[1753890756.547357][117:117] CHIP:DL: Wrote settings to /data/chip_counters.ini
[1753890756.547368][117:117] CHIP:DL: NVS set: chip-counters/reboot-count = 1 (0x1)
[1753890756.548826][117:117] CHIP:DL: Wrote settings to /data/chip_counters.ini
[1753890756.548836][117:117] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1753890756.550287][117:117] CHIP:DL: Wrote settings to /data/chip_counters.ini
[1753890756.550298][117:117] CHIP:DL: NVS set: chip-counters/boot-reason = 0 (0x0)
[1753890756.551666][117:117] CHIP:DL: Wrote settings to /data/chip_config.ini
[1753890756.551676][117:117] CHIP:DL: NVS set: chip-config/regulatory-location = 0 (0x0)
[1753890756.553057][117:117] CHIP:DL: Wrote settings to /data/chip_config.ini
[1753890756.553070][117:117] CHIP:DL: NVS set: chip-config/location-capability = 2 (0x2)
[1753890756.553311][117:117] CHIP:DL: Got Ethernet interface: eno1
[1753890756.553475][117:117] CHIP:DL: Found the primary Ethernet interface:eno1
[1753890756.553627][117:117] CHIP:DL: Got WiFi interface: wlp58s0
[1753890756.553647][117:117] CHIP:DL: Failed to reset WiFi statistic counts
2025-07-30 17:52:36.553 (MainThread) INFO [chip.storage] Initializing persistent storage from file: /data/chip.json
2025-07-30 17:52:36.554 (MainThread) ERROR [chip.storage] [Errno 2] No such file or directory: '/data/chip.json'
2025-07-30 17:52:36.554 (MainThread) CRITICAL [chip.storage] Could not load configuration from /data/chip.json - resetting configuration...
2025-07-30 17:52:36.554 (MainThread) WARNING [chip.storage] No valid SDK configuration present - clearing out configuration
2025-07-30 17:52:36.554 (MainThread) WARNING [chip.storage] No valid REPL configuration present - clearing out configuration
2025-07-30 17:52:36.624 (MainThread) INFO [chip.CertificateAuthority] Loading certificate authorities from storage...
2025-07-30 17:52:36.624 (MainThread) INFO [chip.CertificateAuthority] New CertificateAuthority at index 1
2025-07-30 17:52:36.627 (MainThread) INFO [chip.FabricAdmin] New FabricAdmin: FabricId: 0x0000000000000002, VendorId = 0x134B
2025-07-30 17:52:36.627 (MainThread) INFO [matter_server.server.stack] CHIP Controller Stack initialized.
2025-07-30 17:52:36.628 (MainThread) INFO [matter_server.server.server] Starting the Matter Server...
2025-07-30 17:52:36.631 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetching the latest PAA root certificates from DCL.
2025-07-30 17:52:39.433 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetched 69 PAA root certificates from DCL.
2025-07-30 17:52:39.434 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetching the latest PAA root certificates from Git.
2025-07-30 17:52:39.959 (MainThread) INFO [matter_server.server.helpers.paa_certificates] Fetched 2 PAA root certificates from Git.
2025-07-30 17:52:39.961 (MainThread) INFO [chip.FabricAdmin] Allocating new controller with CaIndex: 1, FabricId: 0x0000000000000002, NodeId: 0x000000000001B669, CatTags: []
2025-07-30 17:52:40.047 (MainThread) INFO [matter_server.server.vendor_info] Loading vendor info from storage.
2025-07-30 17:52:40.047 (MainThread) INFO [matter_server.server.vendor_info] Loaded 0 vendors from storage.
2025-07-30 17:52:40.047 (MainThread) INFO [matter_server.server.vendor_info] Fetching the latest vendor info from DCL.
2025-07-30 17:52:40.303 (MainThread) INFO [matter_server.server.vendor_info] Fetched 336 vendors from DCL.
2025-07-30 17:52:40.303 (MainThread) INFO [matter_server.server.vendor_info] Saving vendor info to storage.
2025-07-30 17:52:40.308 (MainThread) INFO [matter_server.server.device_controller] Loaded 0 nodes from stored configuration
2025-07-30 17:52:40.317 (MainThread) INFO [matter_server.server.server] Matter Server successfully initialized.
Ruggy, did you ever get this working?
I installed the Matter Server some time ago and have several devices working. My host is a Pi5 with the HA OS, connected via Ethernet. after, I configured the SLZB radio 1 as you did. I can not get the Thread to configure a router.
