Problem with installing HACS
I cannot get HACS to install via Github- what am I doing wrong?
you are not reading/copying the instructions correctly
Please pay attention to the instructions
it is cd /config, not cd / config, and an enter after that
it is wget -O - https://gat hacs.xyz | bash - and not w get
afbeelding
still wrong
Thanks- Have tried, but now get this:
I am sorry for being direct but do you read what you are typing/copying?
Look at (e.g.) my screenshot…it is GET not GAT
afbeelding
gethacs.xyz
not
gat hacs.xyz
Thank you!
Getting there, so what option do I now select?
You are still not typing what is shown . There is a space between - and https
Thanks!
All now sorted. Thank you for bearing with me!!!
Let me translate, that may help you: command line in linux is made up of tokens separated by spaces
wget is a web downloader
-O is an option to wget, it sets where the download output goes
- is a shortcut for std output (don't worry too much, it is an imaginary but helpful pipe to put stuff
https://get.hacs.xyz is the place on the web that you are telling wget to get
| is a pipe command, take the output of the stuff on the left into the command on the right
bash is the command that executes a script
- this time is stdin, or the other end of the pipe
So that one line asks wget to download something from the website get.hacs.xyz and then treat it as a script which bash runs.
That is spot on, thanks for your assistance.
