I wanted to make an attempt to switch from a Raspberry Pi 4 4GB with M.2 SSD to the old laptop that I used every day… but during the installation of home assistant I had a problem… at the first moment in which I managed to accessing the first loading page of home I received the message “ERROR DURING INSTALLATION” and from that moment on I was no longer able to access home assistant.
I attach the logs:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[09:28:50] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[09:28:50] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
2024-04-07 09:28:51.827 INFO (MainThread) [__main__] Initializing Supervisor setup
2024-04-07 11:28:51.874 INFO (MainThread) [supervisor.bootstrap] Setting up coresys for machine: generic-x86-64
2024-04-07 11:28:51.880 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.03.1
2024-04-07 11:28:51.880 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2024-04-07 11:28:51.971 INFO (SyncWorker_0) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/amd64-hassio-supervisor:2024.03.0']
2024-04-07 11:28:52.656 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2024-04-07 11:28:52.658 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-04-07 11:28:52.659 INFO (MainThread) [__main__] Setting up Supervisor
2024-04-07 11:28:52.873 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2024-04-07 11:28:53.020 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2024-04-07 11:28:53.021 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2024-04-07 11:28:53.022 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2024-04-07 11:28:53.022 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2024-04-07 11:28:53.022 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2024-04-07 11:28:53.022 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2024-04-07 11:28:53.023 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2024-04-07 11:28:53.023 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2024-04-07 11:28:53.023 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2024-04-07 11:28:53.024 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2024-04-07 11:28:53.293 INFO (MainThread) [supervisor.host.services] Updating service information
2024-04-07 11:28:53.297 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-04-07 11:29:03.617 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-04-07 11:29:03.661 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2024-04-07 11:29:03.683 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2024-04-07 11:29:03.684 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2024-04-07 11:29:03.865 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.03.1
2024-04-07 11:29:03.904 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.03.0
2024-04-07 11:29:03.917 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2024-04-07 11:29:03.934 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
2024-04-07 11:29:03.952 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
2024-04-07 11:29:03.969 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0
2024-04-07 11:29:03.981 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
2024-04-07 11:29:03.989 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
2024-04-07 11:29:03.995 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
2024-04-07 11:29:04.033 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 12.1 / BootSlot A
2024-04-07 11:29:04.273 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
2024-04-07 11:29:04.274 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2024-04-07 11:29:04.275 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
2024-04-07 11:29:04.538 INFO (MainThread) [supervisor.store] Loading add-ons from store: 77 all - 77 new - 0 remove
2024-04-07 11:29:04.563 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
2024-04-07 11:29:04.603 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
2024-04-07 11:29:04.603 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2024-04-07 11:29:04.603 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2024-04-07 11:29:04.604 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2024-04-07 11:29:04.604 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-04-07 11:29:04.604 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2024-04-07 11:29:04.604 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-04-07 11:29:04.604 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2024-04-07 11:29:04.605 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-04-07 11:29:04.605 INFO (MainThread) [__main__] Running Supervisor
2024-04-07 11:29:04.614 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
2024-04-07 11:29:04.625 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2024-04-07 11:29:04.629 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
2024-04-07 11:29:04.629 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
2024-04-07 11:29:04.632 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
2024-04-07 11:29:04.632 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
2024-04-07 11:29:04.636 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2024-04-07 11:29:04.637 INFO (MainThread) [supervisor.core] Supervisor is up and running
2024-04-07 11:29:04.637 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
2024-04-07 11:29:04.637 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2024.4.1
2024-04-07 11:29:04.637 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2024.4.1.
2024-04-07 11:29:04.638 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-04-07 11:29:04.638 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-04-07 11:29:04.638 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-04-07 11:29:04.638 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-04-07 11:29:04.661 INFO (MainThread) [supervisor.host.services] Updating service information
2024-04-07 11:29:04.662 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-04-07 11:29:04.662 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-04-07 11:29:04.662 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2024-04-07 11:29:04.662 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2024-04-07 11:29:04.663 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-04-07 11:29:04.663 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-04-07 11:29:04.663 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-04-07 11:29:04.663 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-04-07 11:29:04.664 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-04-07 11:29:04.671 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-04-07 11:29:04.672 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-04-07 11:29:04.693 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-04-07 11:29:04.693 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-04-07 11:29:04.769 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-04-07 11:29:04.778 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-04-07 11:29:04.827 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-04-07 11:29:04.827 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-04-07 11:29:04.827 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-04-07 11:29:25.406 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/bus/usb/001/003 - None
2024-04-07 11:29:25.443 INFO (MainThread) [supervisor.hardware.monitor] Detecting add hardware /dev/ttyACM0 - /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20230803190100-if00
2024-04-07 11:29:25.443 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-377' coro=<HomeAssistant._hardware_events() done, defined at /usr/src/supervisor/supervisor/homeassistant/module.py:311> exception=AwesomeVersionCompareException("Can't compare <unknown landingpage> and <CalVer 2021.9.0>")>
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 316, in _hardware_events
or self.version < "2021.9.0"
File "/usr/local/lib/python3.12/site-packages/awesomeversion/awesomeversion.py", line 172, in __lt__
raise AwesomeVersionCompareException(
awesomeversion.exceptions.AwesomeVersionCompareException: Can't compare <unknown landingpage> and <CalVer 2021.9.0>
