Problem with integral sensor
Hi, for the past few days, I’ve been having an issue with an integral sensor. I changed the syntax of the source sensor.
At the top, there’s the integral sensor. Its value only updates when the entity at the bottom changes, which happens at the end of the charging session.
Is there a way to configure the integral sensor to update every minute instead of only when the value changes?
Thanks!
Set the ‘Max sub-interval’ in the integral helper settings.
My bad! Thank you that was easy!
