Hi everybody,
I made a fresh install of hassbian and i restore the files that I have backuped.
Everything works fine except the logbook and the history.
The database is on the good directory but no new datas saved …
Could you help me ?
Hi everybody,
Could you help me ?
somebody could help me for that issue ?
If you dont need the old data stop home assistant and delete the log and history db files. They will be recreated when HA is restarted.
Thank you for your answer but how can I restore the old datas after that ?
You probably can’t. Which is why I said " If you dont need the old data …"
Ok, I will do that but I will try to move the old data in the new database.
Do you know the format of the database ?
SQLite for the database:
The log file is plain text.
