Problem with maxcio devices
Hello, good morning from Spain. My name is Jose and I am starting out in the world of HA. I have a small problem… In my home I have several smart devices installed in the smart life application, smart plugs, RGB bulbs and electric blinds. I have integrated almost everything in HA with the TUYA plugin. But the blinds don’t work for me.
Captura de pantalla 2024-08-09 115705
Any idea where the problem may be?
If it is a WiFi device you are out of luck as the device is unsupported by Tuya.
If it is Zigbee you can try ZHA or Z2M to see if the device is supported.
Hello, since I have to use the translator, I may not express myself completely clearly. The device does work for me from tuya or smartlife, the problem is when I try to add it to home assistant.
The HA Tuya integration does NOT support your device. See the red square in the image below.
