Returned from vacation last night. At that time everything was still working fine. I could operate all my lamps and I saw the temperature values of my smoke detectors, etc. Since this afternoon everything suddenly stopped working, several backups were restored. Finally that of the night from Thursday to Friday. I did this because I installed all the updates that were ready last night. Unfortunately the problem is still there.
Is it running? Add-on? Logs?
Check Settings → System → Repairs.
There was an automatic update to the supervisor recently that requires a few restarts for addons.
Okay is i have see that yesterday en run the fixes.
But now i have restored an backup because the problem was today.
Now there are no fixes: There are currently no repairs available
Was the backup from before or after all your updates and repairs?
What errors do you see in Settings → System → Logs ?
Before the updates. Yesterday (Friday) i came back from holiday. The backup is from Thursday/Friday Night.
Full log of Mosquitto broker:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[19:45:25] INFO: Setting up user mosquitto
[19:45:26] INFO: Certificates found: SSL is available
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[19:45:28] INFO: Starting NGINX for authentication handling…
s6-rc: info: service legacy-services successfully started
[19:45:29] INFO: Starting mosquitto MQTT broker…
2023-07-01 19:45:29: Warning: Mosquitto should not be run as root/administrator.
[19:45:34] INFO: Successfully send discovery information to Home Assistant.
[19:45:35] INFO: Successfully send service information to the Supervisor.
2023-07-01 19:45:29: mosquitto version 2.0.15 starting
2023-07-01 19:45:29: Config loaded from /etc/mosquitto/mosquitto.conf.
2023-07-01 19:45:29: Loading plugin: /usr/share/mosquitto/go-auth.so
2023-07-01 19:45:29: ├── Username/password checking enabled.
2023-07-01 19:45:29: ├── TLS-PSK checking enabled.
2023-07-01 19:45:29: └── Extended authentication not enabled.
2023-07-01 19:45:29: Opening ipv4 listen socket on port 1883.
2023-07-01 19:45:29: Opening ipv6 listen socket on port 1883.
2023-07-01 19:45:29: Opening websockets listen socket on port 1884.
2023-07-01 19:45:29: Opening ipv4 listen socket on port 8883.
2023-07-01 19:45:29: Opening ipv6 listen socket on port 8883.
2023-07-01 19:45:29: Opening websockets listen socket on port 8884.
2023-07-01 19:45:29: mosquitto version 2.0.15 running
2023-07-01 19:45:31: New connection from 127.0.0.1:32822 on port 1883.
2023-07-01 19:45:31: Client closed its connection.
2023-07-01 19:45:51: New connection from 172.30.32.1:51999 on port 1883.
2023-07-01 19:45:51: New client connected from 172.30.32.1:51999 as 0TvydPjFMVfHkRcazP4GNR (p2, c1, k60, u’homeassistant’).
2023-07-01 19:47:30: New connection from 172.30.33.4:51396 on port 1883.
2023-07-01 19:47:30: New client connected from 172.30.33.4:51396 as mqttjs_1262aec3 (p2, c1, k60, u’mosquitto’).
2023-07-01 19:48:45: New connection from 172.30.32.2:53108 on port 1883.
2023-07-01 19:48:45: Client closed its connection.
2023-07-01 19:50:45: New connection from 172.30.32.2:41400 on port 1883.
2023-07-01 19:50:45: Client closed its connection.
2023-07-01 19:51:46: Client 0TvydPjFMVfHkRcazP4GNR closed its connection.
2023-07-01 19:52:29: New connection from 172.30.32.1:40319 on port 1883.
2023-07-01 19:52:29: New client connected from 172.30.32.1:40319 as 1TOMQZnpmCjWDHQHJqMqUJ (p2, c1, k60, u’homeassistant’).
2023-07-01 19:52:45: New connection from 172.30.32.2:44884 on port 1883.
2023-07-01 19:52:45: Client closed its connection.
2023-07-01 19:54:45: New connection from 172.30.32.2:42978 on port 1883.
2023-07-01 19:54:45: Client closed its connection.
2023-07-01 19:56:45: New connection from 172.30.32.2:37678 on port 1883.
2023-07-01 19:56:45: Client closed its connection.
2023-07-01 19:58:45: New connection from 172.30.32.2:35070 on port 1883.
2023-07-01 19:58:45: Client closed its connection.
2023-07-01 20:00:45: New connection from 172.30.32.2:51948 on port 1883.
2023-07-01 20:00:45: Client closed its connection.
2023-07-01 20:02:45: New connection from 172.30.32.2:38234 on port 1883.
2023-07-01 20:02:45: Client closed its connection.
2023-07-01 20:04:45: New connection from 172.30.32.2:51846 on port 1883.
2023-07-01 20:04:45: Client closed its connection.
2023-07-01 20:06:45: New connection from 172.30.32.2:58080 on port 1883.
2023-07-01 20:06:45: Client closed its connection.
2023-07-01 20:08:45: New connection from 172.30.32.2:38254 on port 1883.
2023-07-01 20:08:45: Client closed its connection.
2023-07-01 20:10:45: New connection from 172.30.32.2:33210 on port 1883.
2023-07-01 20:10:45: Client closed its connection.
2023-07-01 20:12:45: New connection from 172.30.32.2:48990 on port 1883.
2023-07-01 20:12:45: Client closed its connection.
2023-07-01 20:14:45: New connection from 172.30.32.2:57124 on port 1883.
2023-07-01 20:14:45: Client closed its connection.
2023-07-01 20:15:32: Saving in-memory database to /data//mosquitto.db.
2023-07-01 20:16:45: New connection from 172.30.32.2:41744 on port 1883.
2023-07-01 20:16:45: Client closed its connection.
2023-07-01 20:18:45: New connection from 172.30.32.2:45906 on port 1883.
2023-07-01 20:18:45: Client closed its connection.
2023-07-01 20:20:45: New connection from 172.30.32.2:33208 on port 1883.
2023-07-01 20:20:45: Client closed its connection.
2023-07-01 20:22:45: New connection from 172.30.32.2:55330 on port 1883.
Now to update everything again and see if the problem resolves itself, I have no idea what to do anymore
The error in your core log indicates a malformed retained discovery message.
Without deleting that from the broker you may end up with the same problem.
There was an update for zigbee2mqtt, i had already installed this update. Now i have it installed on the home assistant version that was running on the day when i was comming back from the holiday. That fixed the problem.
I have now installed all updates and the problem is not comming back. Very strange problem. But it is fixed
