Problem with motion sensors in the ADT Pulse MQTT add-on
I’m hoping that someone can help me figure out why my motion sensors don’t triggering a state change using the ADT Pulse MQTT add-on.
I’m a relative noob with Home Assistant and MQTT. I’m currently running Hassio v0.85.1 on a Rasberry Pi, and have installed the ADT Pulse MQTT add-on v0.2.2.8.
I can use the add-on to arm/disarm my control panel (once I updated to v0.2.2.8), and my binary_sensors for my door zones trigger state changes as expected. None of the binary_sensors for motion detection, however, trigger.
For example, if I SSH into Hassio and subscribe to messages regarding motion in my master using:
# mosquito_sub –h <my ip address> -t ‘adt/zone/Master Room Motion/state’ –u <my username> -P <my password> -d
I do see messages like this in the add-on’s log when I move around in my Master Room:
Client mosqsub|58-core-ssh received PUBLISH (d0, q0, r0, m0, 'adt/zone/Master Room Motion/state', ... (213 bytes))
{"id":"sensor-22","devIndex":"E8VER1","name":"Master Room Motion","tags":"sensor,motion","status":"devStatMotion","statusTxt":"Master Room Motion - Motion\nLast Activity: Today 3:38 PM","activityTs":1548027532532}
But I see the following warning in my log:
019-01-20 15:38:57 WARNING (MainThread) [homeassistant.components.binary_sensor.mqtt] No matching payload found for entity: Master Room Motion with state_topic: adt/zone/Master Room Motion/state`
And, the card for my motion detectors never changes.
Here is part of my binary_sensor.yaml (showing the configuration for both a door, which works, and a motion sensor, which doesn’t work)
- platform: mqtt
  name: "Back Garage Door"
  device_class: door
  state_topic: "adt/zone/Outside Garage Door/state"
  payload_on: "devStatOpen"
  payload_off: "devStatOK"
  retain: true
  value_template: '{{ value_json.status }}'
- platform: mqtt
  name: "Family Room Motion"
  device_class: motion
  state_topic: "adt/zone/Family Room Motion/state"
  retain: true
and here is the configuration for the add-on:
  "ssl": false,
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem",
  "pulse_login": {
    "username": "<my username>",
    "password": "<my password>"
  "mqtt_host": "core-mosquitto",
  "mqtt_url": "",
  "mqtt_connect_options": {
  "alarm_state_topic": "home/alarm/state",
  "alarm_command_topic": "home/alarm/cmd",
  "zone_state_topic": "adt/zone",
  "smartthings_topic": "smartthings",
  "smartthings": false
Anyone have any ideas why my motion sensors aren’t working?
Simple/stupid mistake on my part. In my binary_sensors.yaml I needed to replace:
with:
payload_on: "devStatMotion"
for all motion sensors
mqtt:
   alarm_control_panel:
     - name: "ADT Pulse"
       state_topic: "home/alarm/state"
       command_topic: "home/alarm/cmd"
       payload_arm_home: "arm_home"
       payload_arm_away: "arm_away"
       payload_disarm: "disarm"
   binary_sensor:
     - name: "Living Door"
       state_topic: "adt/zone/Living Door/state"
       device_class: door
     - name: "Master Smoke"
       state_topic: "adt/zone/Master Smoke/state"
       payload_on: "devStatAlarm"
       payload_off: "Okay"
       device_class: smoke
````Preformatted text`
I have added this in my configuration Alarm working perfectly but  all of my binary_sensor are giving "Unknown Status", can any one tell me which part i'm missing here- i have added  the list of my sensors
![ADt sensor|242x500](upload://rrq4lQoroxnccPBGj8tloJ7JqRB.jpeg)
here are the list of my sensor from ADT PORTAL
