Problem with Nest integration
I am trying to setup the Nest integration, and I followed all the steps successfully, however after the integration has been added, I get the following error:
Retrying setup: Device manager error: Error connecting to API: Cannot connect to host smartdevicemanagement.googleapis.com:443 ssl:default [Network unreachable]
I am able to ssh into the server running home assistant, and running curl https://smartdevicemanagement.googleapis.com works just fine.
Any idea what is going on?
