I have Home Assistant running on RPi 4, and im trying to setup remote access using this simple tutorial (starts at about 7:49)
Problem is, when I want to enable SSL certificates and force SSL and press enter, it says “internal error”. The log file shows this towards the end:
[2/19/2022] [9:09:10 AM] [Nginx ] › ℹ info Reloading Nginx
[2/19/2022] [9:09:10 AM] [SSL ] › ℹ info Requesting Let'sEncrypt certificates for Cert #5: XXX.duckdns.org
[2/19/2022] [9:09:16 AM] [Nginx ] › ℹ info Reloading Nginx
[2/19/2022] [9:09:16 AM] [Express ] › ⚠ warning Command failed: /usr/bin/certbot certonly --non-interactive --config "/etc/letsencrypt.ini" --cert-name "npm-5" --agree-tos --email "[email protected]" --preferred-challenges "dns,http" --domains "XXX.duckdns.org"
Saving debug log to /data/logs/letsencrypt/letsencrypt.log
Plugins selected: Authenticator webroot, Installer None
Performing the following challenges:
http-01 challenge for XXX.duckdns.org
Using the webroot path /data/letsencrypt-acme-challenge for all unmatched domains.
Waiting for verification...
Challenge failed for domain XXX.duckdns.org
Cleaning up challenges
Some challenges have failed.
I’ve confirmed with my ISP and port checker, that port 80 is not blocked. I can actually login to my HA using my duckDNS url (on a different network) with HTTP only. How do I enable SSL?
Before this, I had DuckDNS with SSL enabled and working. I unsinstalled DuckDNS and MariaDB and then I reinstalled them again…but still geting this error.
Any help would be appreciated.
