NIC/NUC problems.
I need some advice for using the pve on my NUC.
I see the message described here: https://forum.proxmox.com/threads/e1000-driver-hang.58284/page-5
I was wondering if any of you guys have solved it successfully.
I’ve tried using the ethtool thing, and I’m awaiting the result, but I can see that transfer rates are being punished by this. I’m unsure if what I see is ‘the old bug’ or ‘the new kernel bug’.
Should I go to vmware instead? I really do like pve and qvm, but I can’t base the HA on a platform that will crash all the time.
Hi did you ever get this sorted?
Do you know if you can you use ethtool in Home Assistant?
I’m having similar issues on a NUC.
For me I have to run this command after I restart my proxmox:
ethtool -K eno1 gso off gro off tso off tx off rx off
Where eno1 is the NIC name
