Problem with openWakeWord
Hi everyone,
I’m currently using four M5Stack Atom Echo devices as voice assistants at home. Each device is set up with Google Cloud Speech-to-Text for recognition, Google Generative AI for conversation, and Google Text-to-Speech for responses. Additionally, I’ve configured custom wake words for each device.
However, I’ve been encountering an issue where these devices intermittently stop responding to their wake words after about 10 cycles of use. For instance, despite it being 7:45 now, the most recent activity recorded was at 19:31. To temporarily resolve this, I’ve found that clicking the button multiple times and holding it until the red light flashes seems to reset them, allowing functionality for another 10 cycles.
I suspect the problem might be related to the openwakeword software or potentially an issue with the devices themselves, although all four devices are affected, suggesting a systemic issue. Another consideration could be limitations in the Assistant’s support for a certain number of conversation sessions.
Below is the configuration I’m using for one of the M5Stack Echo devices:
esphome:
  friendly_name: m5stack-assist-master
  name_add_mac_suffix: true
  project:
    version: "1.0"
  min_version: 2023.11.1
logger:
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  on_connect:
    - delay: 5s  # Gives time for improv results to be transmitted
    - ble.disable:
  on_disconnect:
    - ble.enable:
  ap:
    ssid: "M5Stack-Assist-Master"
    password: "HGckieosx"
captive_portal:
esp32:
  board: m5stack-atom
  framework:
    type: esp-idf
dashboard_import:
  package_import_url: github://esphome/firmware/voice-assistant/m5stack-atom-echo.yaml@main
improv_serial:
esp32_improv:
  authorizer: none
button:
  - platform: factory_reset
i2s_audio:
  i2s_lrclk_pin: GPIO33
  i2s_bclk_pin: GPIO19
microphone:
  - platform: i2s_audio
    i2s_din_pin: GPIO23
    adc_type: external
    pdm: true
speaker:
    i2s_dout_pin: GPIO22
    dac_type: external
    mode: mono
voice_assistant:
  microphone: echo_microphone
  speaker: null
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  vad_threshold: 3
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Slow Pulse"
  on_stt_vad_end:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Fast Pulse"
  on_tts_start:
    - light.turn_on:
        blue: 0%
        red: 0%
        green: 100%
        brightness: 100%
        effect: none
    - homeassistant.service:
        service: script.r6_tts
        data_template:
          message: !lambda 'return x;'
          device: 'media_player.gghmini_master_2'
          volume: '0.5'
  on_tts_end:
  - light.turn_on:
      blue: 100%
      red: 0%
      green: 100%
      brightness: 100%
      effect: none
  on_end:
    - delay: 100ms
    - script.execute: reset_led
  on_error:
    - light.turn_on:
        red: 100%
        green: 0%
        blue: 0%
        brightness: 100%
        effect: none
    - delay: 1s
  on_client_connected:
    - if:
        condition:
          switch.is_on: use_wake_word
        then:
          - voice_assistant.start_continuous:
  on_client_disconnected:
    - if:
        condition:
        then:
          - voice_assistant.stop:
          - light.turn_off: led
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO39
      inverted: true
    disabled_by_default: true
    entity_category: diagnostic
    on_multi_click:
      - timing:
          - ON for at least 250ms
          - OFF for at least 50ms
        then:
          - if:
              condition:
                switch.is_off: use_wake_word
              then:
                - if:
                    condition: voice_assistant.is_running
                    then:
                    else:
                      - voice_assistant.start:
              else:
                - delay: 1s
                - script.wait: reset_led
      - timing:
          - ON for at least 10s
        then:
          - button.press: factory_reset_btn
light:
  - platform: esp32_rmt_led_strip
    entity_category: config
    pin: GPIO27
    default_transition_length: 0s
    chipset: SK6812
    num_leds: 1
    rgb_order: grb
    rmt_channel: 0
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
script:
  - id: reset_led
    then:
      - if:
          condition:
            - switch.is_on: use_wake_word
            - switch.is_on: use_listen_light
          then:
            - light.turn_on:
                red: 100%
                green: 89%
                blue: 71%
                brightness: 60%
                effect: none
          else:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
    name: Use listen light
    optimistic: true
    on_turn_on:
    on_turn_off:
external_components:
  - source: github://pr#5230
    components:
      - esp_adf
    refresh: 0s
esp_adf:
Note: I have edited the original script to repeat the output in a different speaker
Has anyone else encountered similar issues with M5Stack devices or voice assistants in general? Any insights or suggestions for troubleshooting would be greatly appreciated.
Thanks!
Hi!
@AKT311209 Did you manage to solve the issue? I faced the exact same problem also I modified the original script to get the output in another speaker.
