Problem with OpenZwave and Zwave.me wall flush-mountable
I have a really strange problem with one of my two zwave.me wall flush-mountables (switches). They worked both as expected. Maybe until I changed the config directory to the newest version of openzwave.
The problem is, that one switch turn off immediately after it is turned on. And curiously the state in the openzwave controlpanel don’t switch back to off. The state remains on. The other works fine, stay turned on and the state is represented correctly in openzwave controlpanel. It doesn’t seem to be a problem of home-assistant because it doesn’t work with openzwave only. They both have the same openzwave default configuration. I compared the configuration lines from both in the saved zwcfgxxxx.xml file. I included and excluded both mountables several times with no result. I looked into the OZWlog.txt and couldn’t see any errors.
By the way: I excluded the switch and without openzwave it work as a normal switch and stay turned on. The switch isn’t damaged.
Has someone of you experienced the same behavior? I would be pleased to hear from you.
UPDATE: The solution was to replace the switch - unfortunately it was defect.
