Hi everyone,I’m having trouble with my Home Assistant dashboard configuration using the picture-elements
card. I have set up a visual floor plan where images should update based on the state of two light entities. Here’s the issue:
- Entities:
light.esszimmer_4
andlight.balkon_4
- Expected Behavior: The image should change when the state of either light is toggled via the
state-icon
. - Issue:
- The image updates correctly when I toggle
light.balkon_4
. - However, when I toggle
light.esszimmer_4
, the image does not update, although the light state changes as expected.
Here’s the full YAML configuration I’m using:
type: picture-elements
image: local/FloorPlan/floorBase.png
elements:
- type: image
entity: light.esszimmer_4
state_image:
'on': local/FloorPlan/floorEsszimmer.png
'off': local/FloorPlan/floorBase.png
style:
left: 50%
top: 50%
width: 100%
tap_action:
action: none
- type: image
entity: light.balkon_4
state_image:
'on': local/FloorPlan/floorBalkon.png
style:
left: 50%
top: 50%
width: 100%
tap_action:
action: none
- type: state-icon
style:
left: 30%
top: 66%
opacity: 100%
tap_action:
action: toggle
- type: state-icon
style:
left: 16%
top: 50%
opacity: 100%
tap_action:
action: toggle
What I’ve Tried:
- Verified that both light entities change state correctly in the Home Assistant UI.
- Checked that the image paths are correct and accessible.
- Removed the
state-icon
andimage
elements individually to test functionality, which works when isolated.
Additional Context:
- I’m using the latest version of Home Assistant.
- The issue is consistent across different browsers and devices.
I’m looking for any insights or suggestions on why the image for light.esszimmer_4
might not be updating when both elements are included. Any help would be greatly appreciated!Thank you! This format gives a clear picture of your setup and the specific problem you’re encountering, making it easier for others to provide targeted assistance.
