I have strange problem - I bought raspbee + raspberry 3 b+.
Installed HASS and deconz plugin by marthoc
Updated config and settings - and was able to connect Keen.home vents to deconz via web ui - as lights. Everything worked until reboot. After reboot - I unable to control anything - sliders on light doing nothing with vents.
VNC’ing into Deconz - showing mesh as active and devices visible - if open ‘Signal Monitor Plugin’ for specific vent - and click start/stop - after it - vents start working again inside webui and inside home assistant.
Another reboot - and it stops working. Only way to may it work - reset and add as new devices or use VNC + Signal Plugin
Any ideas ?
p.s. I use latest versions of everything
