Hi all
I have installed Home Assistant 2022.4.7, in Home Assistant OS.
I am experiencing some issues with core integrations, but also third parties integrations.
It seem my HA installation cannot install external libraries.
This is the log result when I try to install the core integration PVPC hour pricing through the UI flowchart (Spain electricity hourly pricing (PVPC) - Home Assistant). The configuration flowchart throws an error, cannot be loaded.
Any suggestion of what is happening?
Logger: aiohttp.server
Source: requirements.py:194
First occurred: 12:21:40 (1 occurrences)
Last logged: 12:21:40
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 94, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 79, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 219, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 174, in post
return await super().post(request)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 71, in post
result = await self._flow_mgr.async_init(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 205, in async_init
flow, result = await task
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 223, in _async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 740, in async_create_flow
await async_process_deps_reqs(self.hass, self._hass_config, integration)
File "/usr/src/homeassistant/homeassistant/setup.py", line 360, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
File "/usr/src/homeassistant/homeassistant/requirements.py", line 83, in async_get_integration_with_requirements
await _async_process_integration(hass, integration, done)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 99, in _async_process_integration
await async_process_requirements(
File "/usr/src/homeassistant/homeassistant/requirements.py", line 162, in async_process_requirements
await _async_process_requirements(
File "/usr/src/homeassistant/homeassistant/requirements.py", line 194, in _async_process_requirements
raise RequirementsNotFound(name, [req])
homeassistant.requirements.RequirementsNotFound: Requirements for pvpc_hourly_pricing not found: ['aiopvpc==2.2.1'].
