Problem with restart
HI
sometime i am facing reboot problem ,below is log where it stuck
17-03-21 23:35:12 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_stop[L]>
17-03-21 23:35:12 INFO (Thread-5) [homeassistant.components.zwave] Stopping ZWave network.
17-03-21 23:35:12 INFO (Thread-5) [openzwave] Stop Openzwave network.
17-03-21 23:35:12 INFO (Thread-5) [openzwave] ZWave configuration written to user directory.
17-03-21 23:35:12 WARNING (MainThread) [aiohttp.websocket] websocket connection is closing.
17-03-21 23:35:17 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_close[L]>
please let me know whats problem why some time it stuck here need to reboot device
Did you fix it?
No
never lots of update done but still same i have to reboot pi3 manually from shell.
if any one get solution let me know
I now have the problem too.
Using Server Management , Restart does not work (results in nginx error)
But restarting the device using SSH does work.
I have version 111.2 in docker compose.
It has been working fine until this version.
docker-compose restart also works
