Problem with Ring integration - last few weeks but bad today: Error fetching Ring active dings data
For months the Rung integration and doorbell worked very well and reliably. But over the past couple of weeks it keeps failing to activate the “ding” sensor. Typically, after a reboot it works once and then fails. I’m notaware of making any changes that should affect this.
My System currently - no March updates applied as seemed to break DeConz for me.
Home Assistant 2023.2.5
Supervisor 2023.03.1
Operating System 9.5
Frontend 20230202.0 - latest
From the logs:
Logger: homeassistant.components.ring
Source: components/ring/__init__.py:219
Integration: Ring ([documentation](https://www.home-assistant.io/integrations/ring), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+ring%22))
First occurred: 1:03:13 AM (273 occurrences)
Last logged: 2:16:55 AM
* Error fetching Ring active dings data: HTTPSConnectionPool(host='api.ring.com', port=443): Max retries exceeded with url: /clients_api/dings/active?api_version=9 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f7f013a00>: Failed to establish a new connection: [Errno -3] Try again'))
* Error fetching Ring active dings data: HTTPSConnectionPool(host='api.ring.com', port=443): Max retries exceeded with url: /clients_api/dings/active?api_version=9 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f7f010430>: Failed to establish a new connection: [Errno -3] Try again'))
* Error fetching Ring active dings data: HTTPSConnectionPool(host='api.ring.com', port=443): Max retries exceeded with url: /clients_api/dings/active?api_version=9 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f7f012ec0>: Failed to establish a new connection: [Errno -3] Try again'))
* Error fetching Ring device data: HTTPSConnectionPool(host='api.ring.com', port=443): Max retries exceeded with url: /clients_api/ring_devices?api_version=9 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6b858eb0>: Failed to establish a new connection: [Errno -3] Try again'))
* Error fetching Ring active dings data: HTTPSConnectionPool(host='api.ring.com', port=443): Max retries exceeded with url: /clients_api/dings/active?api_version=9 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f6b7d5900>: Failed to establish a new connection: [Errno -3] Try again'))
And another similar Logged error:
Source: components/ring/__init__.py:311
Integration: Ring (documentation, issues)
First occurred: 1:03:55 AM (23 occurrences)
Last logged: 2:16:53 AM
Error fetching Ring history data for device 083a882a8456: HTTPSConnectionPool(host='api.ring.com', port=443): Max retries exceeded with url: /clients_api/doorbots/74095589/history?api_version=9&limit=10 (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f692579a0>: Failed to establish a new connection: [Errno -3] Try again'))
And more:
Source: components/ring/__init__.py:213
First occurred: 1:02:44 AM (17 occurrences)
Last logged: 2:06:40 AM
Time out fetching Ring active dings data
Time out fetching Ring device data
There is an open GitHub issue that doesn’t appear to be getting any response from the developers.
Thanks. Still same issues. Last ding doesnt get updated immediately
