Problem with saving automation: Message malformed: Integration '' not found
I’d like to have a button with which I can change my heating profile for an hour (such that I don’t forget to set it back). I tried following this solution - the idea is to trigger the automation from a Lovelace button. However, I can’t save it, and the error message is not exactly helpful. It’s probably something stupid, but I don’t want to spend the day blindly trying things :slight_smile: - can anybody help out? Automation code below…
Btw: Might this use case be a candidate for a blueprint?
Thanks in advance
Christian
alias: Wohnzimmerheizung für 1h auf Wärmer
description: ''
mode: single
  - platform: event
    event_type: timer.finished
    event_data:
      entity_id: timer.wohnzimmer_heizung
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: homematicip_cloud.set_active_climate_profile
              climate_profile_index: 2
              entity_id: climate.wohnzimmer
      - conditions:
          - condition: state
            state: idle
        sequence:
              climate_profile_index: 3
          - service: timer.start
              duration: '01:00:00'
      - conditions:
          - condition: state
            state: active
        sequence:
          - service: timer.cancel
    default: []
mode: single
Only thing I see is double use of mode: single (line 3 and last line).
Good catch! That was it… Really appreciate it :smiley:
Now let’s see whether it actually works…
