Problem with Scenes
I’m trying to get some scenes set up but I can’t seem to create even the most basic types of scenes, e.g.:
scene:
  - name: LivingRoomLightsFull
    entities:
      light.ph5_light: on
The error I’m getting on the config check is:
Invalid config for [scene]:
required key not provided @ data[‘states’][0][‘entities’]. Got None
required key not provided @ data[‘states’][0][‘name’]. Got None.
(See /config/configuration.yaml, line 161). Please check the docs at Scenes - Home Assistant
Can’t for the life of me figure out what’s going on. I copied the code straight from the Scenes page on the HA website so I doubt it has to do with any formatting errors in the code. I’ve also double-checked my configuration.yaml and the only reference to scenes is the very last row:
scene: !include scenes.yaml
Remove the line scene: from scenes.yaml
What you’re effectively putting is
scene:
  scene:
    - name: living....
Which is obviously invalid.
Imagine !include to mean “go to the next line, go two spaces in, and insert the contents of the file”.
That did it! Thank you.
Had same issue, worked for me too. Not easy being a noob at this. Thanks man :slight_smile:
