Problem with setting up home assistant
Hi Guys,
I am a new to this, i am running into the below error when executing this command hass --open-ui
File “/Library/Frameworks/Python.framework/Versions/3.6/bin/hass”, line 11, in
sys.exit(main())
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/main.py”, line 359, in main
monkey_patch_asyncio()
File “/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/homeassistant/main.py”, line 58, in monkey_patch_asyncio
asyncio.tasks.Task._all_tasks = IgnoreCalls()
TypeError: can’t set attributes of built-in/extension type ‘_asyncio.Task’
Thanks for the hlp
I read somewhere that HASS only support python 3.5 (maybe 3.4?). So you may need to install a previous version of python.
Hello
I have the same issue with Python 3.4.
New installation and first run with no update of the image hassbian 1.0, on a rp 3.
thanks for help ?
Https://github.com/home-assistant/pi-gen/releases/download/2016-09-19-haspbian-0.2/2016-09-26-Hassbian.zip
