I am new to home assistant. I have a Rapberry PI3 with a communication module HM-MOD-RPI-PCB from ELV.
I have setup the Rapberry PI3 and it is working. I have installed Rasbian Stretch and Home Assistant 0.60.
Homegear is also installed in a docker container.
Communication with the HM-MOD-RPI-PCB module is working. I can pair the Homematic Thermostat with the Homematic Configuration utility. Homegear also sees the Thermostat. I can check this via RPC.
My problem is the Thermostat did not show up in HA. It will not be discovered. What I am doing wrong?
configuration.yaml
logger:
logs:
homeassistant.components.homematic: debug
pyhomematic: debug
homematic:
local_ip: 192.168.0.70
local_port: 36845
interfaces:
wireless:
host: 192.168.0.70 ->Raspberry with HA
port: 2001
callback_ip: 172.17.0.2 -> Docker Containter with Homegear
callback_port: 36845
resolvenames: metadata
home-assistant.log
017-12-27 11:58:26 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=updater>
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.setup] Setting up discovery
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.0 seconds.
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=discovery>
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.setup] Setting up homematic
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic.connection] HMConnection: Creating server object
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic._hm] ServerThread.__init__
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic._hm] __init__: Creating proxies
2017-12-27 11:58:27 INFO (Thread-14) [pyhomematic._hm] Creating proxy wireless. Connecting to http://192.168.0.70:2001
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic._hm] LockingServerProxy.__init__: Getting local ip
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic._hm] LockingServerProxy.__init__: Got local ip 192.168.0.70
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic._hm] RPCFunctions.__init__
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic._hm] RPCFunctions.__init__: iterating proxy = homeassistant-wireless
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic._hm] RPCFunctions.__init__: devices_raw = []
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic._hm] RPCFunctions.createDeviceObjects: iterating interface_id = wireless
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic._hm] ServerThread.__init__: Setting up server
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic._hm] ServerThread.__init__: Registering RPC functions
2017-12-27 11:58:27 INFO (Thread-23) [pyhomematic._hm] Starting server at http://192.168.0.70:36845
2017-12-27 11:58:27 DEBUG (Thread-14) [pyhomematic._hm] ServerThread.proxyInit: init('http://172.17.0.2:36845', 'homeassistant-wireless')
2017-12-27 11:58:27 INFO (Thread-14) [pyhomematic._hm] Proxy initialized
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=virtualkey, domain=homematic>
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=set_variable_value, domain=homematic>
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=reconnect, domain=homematic>
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=set_device_value, domain=homematic>
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=set_install_mode, domain=homematic>
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.setup] Setup of domain homematic took 0.4 seconds.
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=homematic>
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.setup] Setting up conversation
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: service=process, domain=conversation>
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=conversation>
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 6.05s
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Starting Home Assistant core loop
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>
2017-12-27 11:58:27 INFO (MainThread) [homeassistant.core] Timer:starting
2017-12-27 11:58:30 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket to 192.168.0.1 (auth: True)
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Connected
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Received {'type': 'subscribe_events', 'id': 2, 'event_type': 'state_changed'}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Received {'type': 'subscribe_events', 'id': 3, 'event_type': 'component_loaded'}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Sending {'success': True, 'type': 'result', 'result': None, 'id': 2}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Sending {'success': True, 'type': 'result', 'result': None, 'id': 3}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Received {'type': 'subscribe_events', 'id': 4, 'event_type': 'service_registered'}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Received {'type': 'subscribe_events', 'id': 5, 'event_type': 'service_removed'}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Received {'type': 'subscribe_events', 'id': 6, 'event_type': 'themes_updated'}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Received {'type': 'get_states', 'id': 7}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Received {'type': 'get_config', 'id': 8}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Received {'type': 'get_panels', 'id': 9}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Received {'type': 'get_services', 'id': 10}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Sending {'success': True, 'type': 'result', 'result': None, 'id': 4}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Sending {'success': True, 'type': 'result', 'result': None, 'id': 5}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Sending {'success': True, 'type': 'result', 'result': None, 'id': 6}
2017-12-27 11:58:30 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1748442288: Sending {'success': True, 'type': 'result', 'result': [<state persistent_notification.notification=notifying; title=Welcome Home!, message=Here are some resources to get started:
Any idea what’s wrong with my setup?
Can I use pyhomematic.py to access the Thermostat to check it is working? How can I do that?
EDIT: I just checked if I could communicate and check some values of the thermostat with an example python-script.
Connected to Homegear (version 0.7.10-1397).
families select 0
Device family “HomeMatic BidCoS” selected.
For information about the family’s commands type: “help”
(Family)> pl
ID │ Name │ Address │ Serial Number │ Type │ Type String │ Firmware │ Config Pending │ Unreach │ Low Bat
1 │ HM-CC-RT-DN OEQ16xxxxx │ 5FA1F6 │ OEQ16xxxxx │ 0095 │ HM-CC-RT-DN │ 1.4 │ No │ No │ No
example.py
#!/usr/bin/python3
import time
import sys
import logging
from pyhomematic import HMConnection
logging.basicConfig(level=logging.INFO)
#DEVICE1 = 'address_of_rollershutter_device' # e.g. KEQ7654321
#DEVICE2 = 'address_of_doorcontact' # e.g. LEQ1234567
DEVICE3 = '5FA1F6'
def systemcallback(src, *args):
print(src)
for arg in args:
print(arg)
try:
# Create a server that listens on 127.0.0.1:7080 and identifies itself as myserver.
# Connect to Homegear at 127.0.0.1:2001
# Automatically start everything. Without autostart, pyhomematic.start() can be called.
# We add a systemcallback so we can see what else happens besides the regular events.
pyhomematic = HMConnection(interface_id="myserver",
local="192.168.0.70",
localport=7080,
remote="192.168.0.70",
remoteport=2001,
autostart=True,
systemcallback=systemcallback)
except:
sys.exit(1)
sleepcounter = 0
def eventcallback(address, interface_id, key, value):
print("CALLBACK: %s, %s, %s, %s" % (address, interface_id, key, value))
while not pyhomematic.devices and sleepcounter < 20:
print("Waiting for devices")
sleepcounter += 1
time.sleep(1)
print(pyhomematic.devices)
# Get Actual Temperature
print(pyhomematic.devices[DEVICE3].actual_temperature)
# Get Set Temperature
print(pyhomematic.devices[DEVICE3].set_temperature)
# Get Battery State
print(pyhomematic.devices[DEVICE3].battery_state)
# Stop the server thread so Python can exit properly.
pyhomematic.stop()
sys.exit(0)
Can’t get it to work. Seems the address is wrong…
hass-pi:~ $ ./example.py
INFO:pyhomematic._hm:Creating proxy default. Connecting to http://192.168.0.70:2001
createDeviceObjects
INFO:pyhomematic._hm:Starting server at http://192.168.0.70:9292
INFO:pyhomematic._hm:Proxy initialized
{‘default’: {}}
File “./example.py”, line 46, in
KeyError: ‘5FA1F6’
What’s the correct device address?
regards Tom74
PS: You can also answer me in German if you like.
