And here is the log file;
“home_assistant”: {
“installation_type”: “Home Assistant OS”,
“version”: “2024.11.3”,
“dev”: false,
“hassio”: true,
“virtualenv”: false,
“python_version”: “3.12.4”,
“docker”: true,
“arch”: “x86_64”,
“timezone”: “Europe/Stockholm”,
“os_name”: “Linux”,
“os_version”: “6.6.54-haos”,
“supervisor”: “2024.11.4”,
“host_os”: “Home Assistant OS 13.2”,
“docker_version”: “27.2.0”,
“chassis”: “embedded”,
“run_as_root”: true
“custom_components”: {},
“integration_manifest”: {
“domain”: “shelly”,
“name”: “Shelly”,
“codeowners”: [
“balloob”,
“bieniu”,
“thecode”,
“chemelli74”,
“bdraco”
“config_flow”: true,
“dependencies”: [
“bluetooth”,
“http”,
“network”
“documentation”: “Shelly - Home Assistant”,
“integration_type”: “device”,
“iot_class”: “local_push”,
“loggers”: [
“aioshelly”
“quality_scale”: “platinum”,
“requirements”: [
“aioshelly==12.0.1”
“zeroconf”: [
“type”: “_http._tcp.local.”,
“name”: “shelly*”
“is_built_in”: true,
“overwrites_built_in”: false
“setup_times”: {
“null”: {
“setup”: 0.000157119000050443
“71432179b8ae308dd69bb05583783d36”: {
“wait_import_platforms”: -0.6397551679999651,
“wait_base_component”: -0.002123153000070488,
“config_entry_setup”: 0.6813660980000122
“31e7820b2b5fd7e7e54449ccef7cb752”: {
“wait_import_platforms”: -0.6292760100000123,
“config_entry_setup”: 0.6899601320000102
“f6f9b75d6fe508925f5e1bced8ce40b3”: {
“wait_import_platforms”: -0.6334179630000563,
“config_entry_setup”: 0.6948255560000689
“14f3a1edde710b4d681d3231c8b4b9df”: {
“wait_import_platforms”: -0.5361717739999676,
“config_entry_setup”: 0.697240903000079
“01JDQEWW2FZECT4SW79XR7RYS9”: {
“wait_import_platforms”: -0.5236519449999832,
“config_entry_setup”: 0.6938484410000001
“025bbcdb96fa69ca28f99323b9a9570d”: {
“wait_import_platforms”: -0.11569002299995645,
“wait_base_component”: -0.004204286000003776,
“config_entry_setup”: 0.9241524540000228
“54168081e731335ea389168fc27bf45f”: {
“wait_import_platforms”: -0.16001047299994298,
“config_entry_setup”: 0.9388534830000026
“c7f323cdd7f06b7fe9cba9cd0480f388”: {
“wait_import_platforms”: -0.16840368299995134,
“config_entry_setup”: 0.9499637589999566
“c21ddff02e8d7c5d89041ec4b81ddad0”: {
“wait_import_platforms”: -0.17542537900010302,
“config_entry_setup”: 0.9714062859999331
“97bb0a1788b9aecf637a0ae4adfbe6cf”: {
“wait_import_platforms”: -0.19429121199993915,
“config_entry_setup”: 0.9821408480000855
“55b71fe93d3b3a95a94199bb55160049”: {
“wait_import_platforms”: -0.20186373199999252,
“config_entry_setup”: 0.988396382000019
“1eaba4f659d172900a86e2e1a13e9c47”: {
“wait_import_platforms”: -0.19451823300005344,
“config_entry_setup”: 1.0006276520000483
“334c7e29f875bf47b1652589dfa2e569”: {
“config_entry_setup”: 1.1709331779999275
“426788139170770e1e4e1a50a9ec3492”: {
“config_entry_setup”: 1.1820009529999425
“1bb9c84650aec2126ec01fe2c2fcac08”: {
“config_entry_setup”: 1.1894803139999794
“d71be74efc40077f7ed12afc549f1d8f”: {
“config_entry_setup”: 1.2002406780000001
“d712dc0f812ad1360670415aa9881941”: {
“config_entry_setup”: 1.2069678510000585
“6aff4ca171987b4c0b24c53bc01852c0”: {
“config_entry_setup”: 1.221170577999942
“8616b41e499458415b5a918782cc6301”: {
“config_entry_setup”: 1.248668619
“892b23ce88dfdd841f90295857166379”: {
“config_entry_setup”: 1.2621233569999504
“aee9f37a70a0111832c5854dcff7288f”: {
“config_entry_setup”: 1.2772875970000541
“01JBYHGJYXF0RYV9E5E41A9Z8A”: {
“config_entry_setup”: 1.4750706020000734
“e8796ad659818a98b85965fda5af07b2”: {
“config_entry_setup”: 3.0885098789999574
“901690922dbf0065648f122ce5819039”: {
“config_entry_setup”: 3.149528379000003
“01JD5811Q9050X743Z90TCKVPN”: {
“config_entry_setup”: 3.2982775790000005
“01JBYHFDB43207AMVC70JYDY46”: {
“config_entry_setup”: 10.00319175900006
“data”: {
“entry”: {
“created_at”: “2024-11-20T16:55:57.417578+00:00”,
“data”: {
“gen”: 2,
“host”: “192.168.1.113”,
“model”: “SNSW-001X16EU”,
“sleep_period”: 0,
“port”: 80
“discovery_keys”: {
“zeroconf”: [
“__type”: “<class ‘homeassistant.helpers.discovery_flow.DiscoveryKey’>”,
“repr”: “DiscoveryKey(domain=‘zeroconf’, key=(‘_http._tcp.local.’, ‘shellyplus1-cc7b5c863da8._http._tcp.local.’), version=1)”
“disabled_by”: null,
“domain”: “shelly”,
“entry_id”: “01JD5811Q9050X743Z90TCKVPN”,
“minor_version”: 2,
“modified_at”: “2024-12-03T12:03:20.840982+00:00”,
“options”: {
“ble_scanner_mode”: “disabled”
“pref_disable_new_entities”: false,
“pref_disable_polling”: false,
“source”: “zeroconf”,
“title”: “shellyplus1-cc7b5c863da8”,
“unique_id”: “CC7B5C863DA8”,
“version”: 1
“device_info”: {
“name”: “shellyplus1-cc7b5c863da8”,
“sw_version”: “20231031-152227/1.0.7-g5db02bd”
“device_settings”: {
“cloud”: {
“enable”: false,
“server”: “iot.shelly.cloud:6012/jrpc”
“ws_outbound_enabled”: false
“device_status”: {
“sys”: {
“mac”: “CC7B5C863DA8”,
“restart_required”: false,
“time”: “17:17”,
“unixtime”: 1733246261,
“uptime”: 74668,
“ram_size”: 246160,
“ram_free”: 126628,
“fs_size”: 458752,
“fs_free”: 151552,
“cfg_rev”: 26,
“kvs_rev”: 0,
“schedule_rev”: 0,
“webhook_rev”: 0,
“available_updates”: {
“stable”: {
“version”: “1.3.3”
“wifi”: {
“sta_ip”: “192.168.1.113”,
“status”: “got ip”,
“ssid”: “REDACTED”,
“rssi”: -59
“last_error”: “DeviceConnectionError(TimeoutError())”,
“bluetooth”: “not initialized”
Hope it make sence for you.
