Yes I noticed the same! That is the reason I landed on this page. I took this moment to update the firmware on the shelly h&t and after that I deleted the device from HA and then re-added the device.
FWIW, my device didnât show up in HA until I moved it to the same subnet as HA. I was using a separate IoT network and couldnât figure out how to make the port adjustments needed when the device is on a different subnetâŚ
Thank you so much. I donât know why the Shelly integration page (Shelly - Home Assistant) doesnât mention this. I spent hours trying to get this working and thatâs all it was!
You need to open the firewall in your home LAN to allow the port 8123 traffic to pass from the IOT LAN into your HOME LAN, similar to a port forward, but this is in the firewall settings.
whats the correct one? /shelly not /Shelly right? i changed the url but it keeps changing back to /Shelly
finally managed to do it, you have to the ip and not the name in the url.
with Shelly or shelly? To me it accepted shelly, it found it alone in discovery in home assistant, but keeps in wait with this message
Please wait, starting configuration wizard for the integration
Also I do not understand this
In case your installation is set up to use SSL encryption (HTTP**S** with certificate), an additional `s` needs to be added to the WebSocket protocol,
I mean Sheely are installed locally no? SO I do not understand why shoulf be ssl
Now I received this
Do you want to set up the Shelly H&T Gen3 at 192.168.1.27?
Battery-powered devices that are password protected must be woken up before continuing with setting up.
Battery-powered devices that are not password protected will be added when the device wakes up, you can now manually wake the device up using a button on it or wait for the next data update from the device.
Invalid flow specified
I had the same problem adding these and wonât attempt to explain the why of it but what worked for me was to set up the websocket like:
ws://192.168.1.120:8123/api/shelly/ws
TLS No validation
I have another Home Assistant at our cabin and this worked:
wss://192.168.1.121:8123/api/shelly/ws
Both instances are set up the same so Iâm not sure why one would take the wss and the other would not. I gave up on trying to figure out the âwhyâ since it worked.
Hope this helps. Now to figure out why the Flood sensors are flaky.
