Problem with Shelly Plus 2PM (blinds not calibrated)
I searched a lot but didn’t find a solution for my problem. So I started with Home Assistant a view weeks ago. Now I am moved all my Automations from Apple/Shelly/Amazon. Now I have one single problem left.
I have connected a shelly plus 2PM to the main panel of my blinds. This shelly cannot be calibrated because there is no electric load on it. That is fine for me I only like a switch to open and close all my blinds in the living room.
But the integration is not okay for me. If I use down for a short time the Home Assistant grey out the down button. Same with the up button.
Is there a possibility to always show the button with function? I also do not need the status → open. But I like to have the shelly in shutter mode to avoid an activation of up and down movement → do not know if the old relay do like this on their input lines :wink:
Regards Florian
