Hello, I have different smart contacts from different manufacturers. I have connected them to HOME Assistant with localtuya, but I see that for some the data is updated in a few seconds, and for others the data is updated in 30-120 minutes. But when I enter the tuya app and the problematic devices are updated in a few seconds. How to solve the problem?
Can I set manual time to check update data from devices?
I have seen some problems with localtuya and the tuya app running at the same time . Try to logoff the app first
When you say smart contacts do you mean smart plugs ? if so then i have a lot of those and
sometimes the issue with me is too many devices on the wifi so i added separate wifi to the
IoT devices
But in realty I found it useless to add smart power plugs to HA ( unless they have power monitoring ) given that it does not make real scene to turn on/off devices by cutting power . Only one case was useful for me for a fan .
For the rest of the power plugs and strips I regret buying tuya because sometimes they get messed for no apparent reason ( they comeback when I reboot my router , so that why I added another wifi ) .
Hope this helps
