I flashed some sonoff nimi DIY with Tasmota-basic.bin file (Version is 6.6.0) But Mqtt discover isn’t working with it (Setoption19 1 on) not sure why… I have some sonoff mini devices flashed with tasmota-basic.bin too, but are version 8.1.0, and they was discovered fine. I tried to update by OTA to last binary, but bricked two devices, maybe due to 500k limit. So I decided to add it by yaml. This is my code
switch:
- platform: mqtt
unique_id: DVES_DFB204
state_topic: "home/bedroom/switch1"
command_topic: "home/bedroom/switch1/set"
availability:
- topic: "home/bedroom/switch1/available"
payload_on: "ON"
payload_off: "OFF"
state_on: "ON"
state_off: "OFF"
optimistic: false
qos: 0
retain: true
As I saw in home assistant MQTT help page. The entity now appears in my entities list, but is disabled. I read the mosquitto log, and the device seems to work fine.
Log:
1611585069: New connection from 192.168.1.28 on port 1883.
[INFO] found Mosquitto on Home Assistant
1611585070: New client connected from 192.168.1.28 as DVES_DFB204 (p2, c1, k30, u'Mosquitto').
1611585759: Saving in-memory database to /data/mosquitto.db.
What should I do wrong here?
Is there any updated bin file that don’t brick Sonon mini DIY devices? All are greater than 500k
