Problem with Sonoff P dongle
I’m also having a similar issue but withe the Dongle P
[2024-11-29 16:55:14] info:     z2m: Logging to console, file (filename: log.log)
[2024-11-29 16:55:14] info:     z2m: Starting Zigbee2MQTT version 1.41.0 (commit #69f7282)
[2024-11-29 16:55:14] info:     z2m: Starting zigbee-herdsman (2.1.7)
[2024-11-29 16:55:14] info:     zh:ember: Using default stack config.
[2024-11-29 16:55:14] info:     zh:ember: ======== Ember Adapter Starting ========
[2024-11-29 16:55:14] info:     zh:ember:ezsp: ======== EZSP starting ========
[2024-11-29 16:55:14] info:     zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-11-29 16:55:14] info:     zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-11-29 16:55:14] info:     zh:ember:uart:ash: Serial port opened
[2024-11-29 16:55:14] info:     zh:ember:uart:ash: ======== ASH starting ========
[2024-11-29 16:55:17] info:     zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-11-29 16:55:17] info:     zh:ember:uart:ash: ======== ASH starting ========
[2024-11-29 16:55:19] info:     zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-11-29 16:55:19] info:     zh:ember:uart:ash: ======== ASH starting ========
[2024-11-29 16:55:22] info:     zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-11-29 16:55:22] info:     zh:ember:uart:ash: ======== ASH starting ========
[2024-11-29 16:55:24] info:     zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-11-29 16:55:24] info:     zh:ember:uart:ash: ======== ASH starting ========
[2024-11-29 16:55:27] error:    z2m: Error while starting zigbee-herdsman
[2024-11-29 16:55:27] error:    z2m: Failed to start zigbee
[2024-11-29 16:55:27] error:    z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2024-11-29 16:55:27] error:    z2m: Exiting...
[2024-11-29 16:55:27] error:    z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:684:19)
    at EmberAdapter.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1598:24)
    at Controller.start (/opt/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
    at Zigbee.start (/opt/zigbee2mqtt/lib/zigbee.ts:69:27)
    at Controller.start (/opt/zigbee2mqtt/lib/controller.ts:161:27)
    at start (/opt/zigbee2mqtt/index.js:154:5)
The P is zstack not ember - that’s why
