funkytwig
(Funkytwig)
January 5, 2024, 9:27pm
1
I am running HA on a Pi 3 B+ with hassio. Everything seems to be working but when I try to ssh I get
C:\Users\login\.ssh> ssh [email protected]
Corrupted MAC on input.
ssh_dispatch_run_fatal: Connection to 192.168.0.10 port 22: message authentication code incorrect
Ive been using the setup for several months.
Any idea how to fix this?
DrCos
(Dr Cos)
January 6, 2024, 3:07pm
2
jeedewee
(Jurgen de Wijs)
January 11, 2024, 8:58am
3
@funkytwig I experienced the same issue after updating the SSH plugin on my hassio PC. I got exactly the same error message.
I have tried the solution from @DrCos and it works. Fantastic.
I have made it easier to create a config
file in %systemdrive%%homepath%\.ssh
containing the following:
host ha
HostName 192.168.178.110 #whatever the ip address of your machine is
User root #or hassio in your case
Macs [email protected]
Now you can simply do ssh ha
to connect to the hassio machine.
DrCos
(Dr Cos)
January 13, 2024, 1:51pm
4
nice. Did not know you could do a ‘config’ file in .ssh
Kudos!
mbalsam
(Mitchell Balsam)
January 20, 2024, 11:02pm
5
No need for hmacs in .ssh. One simple change in HA is all that’s required.
-goto Add-ons
-select “advanced ssh & web Terminal”
-click configure
-change the fields sftp and compatibility-mode to true
Then it works
For sftp to work you need to be root
broyuken1
(Broyuken)
February 5, 2024, 10:51pm
6
I get that this is a workaround, but why did this happen in the first place? Should this have been a documented breaking change?
