rjmcfadd
(Ryan)
January 18, 2017, 8:37pm
1
I keep getting the following error when starting HASS:
INFO:homeassistant.util.package:Attempting install of pubnubsub-handler==0.0.7
Then this shows up in the logs:
homeassistant.bootstrap: Not initializing wink because could not install dependency pubnubsub-handler==0.0.7
rpitera
(Robert Pitera)
January 18, 2017, 10:34pm
2
Please include your install method and platform; they’ll be vital in figuring out your issue.
rjmcfadd
(Ryan)
January 18, 2017, 11:31pm
3
Oh sorry, I should have included that. It’s installed on a raspberry pi 3 using the VirtualEnv Linux install method. Thanks.
Having the same problem. Unable to install pubnubsub-handler 0.0.7, and it looks like it was updated to 1.0.0 recently. Hopefully home assistant just needs to use the updated one?
Raspberry Pi 2 with latest Raspbian using manual venv method.
Confirmed that pubnubsub-handler just needs to be bumped to 1.0.0. Looks like it will be fixed by this PR: https://github.com/home-assistant/home-assistant/pull/5425
