I had my home built P1 interface disconnected for some days and then I connected my new Slimmelezer. I uploaded the same code as my old device used to the Slimmelezer before connecting it. I had to fiddle with the device under devices to get it to work, update encryption key for example.
I also think I had to remove the old device and re-add the new one.
The result of this exercise is that my statistics are wrong now, I got -27000KWh that hour.
The problem is shown with this SQL Query that filters out the two id’s where device was disconnected and reconnected:
SELECT *
FROM "statistics"
WHERE metadata_id = 48 AND (id = 1807775 OR id = 1876080)
Result of query:
"id": 1807775,
"created": null,
"metadata_id": 48,
"start": null,
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 41610.332,
"sum": 27210.222,
"created_ts": 1689260410.7797816,
"start_ts": 1689256800.0,
"last_reset_ts": null
"id": 1876080,
"created": null,
"metadata_id": 48,
"start": null,
"mean": null,
"min": null,
"max": null,
"last_reset": null,
"state": 41958.117,
"sum": 0.12099999999918509,
"created_ts": 1690743611.2652175,
"start_ts": 1690740000.0,
The sum is reset for some reason, probably correct and a direct result of my attempts to get the new Slimmelezer to successfully replace my home built one.
Can this be corrected somehow?
I would like to get the statistics correct again…
Thanks in advance!
