I’m trying to setup Switchbot bot S1 without the hub with the below setup with no luck.
I can see new switchbot entity and can add it to the UI but after pressing the button nothing happens:
what hardware is Home Assistant running on? Does it have bluetooth and is it very close to home assistant as a test? Are you 100% sure the Mac is correct
