Hi!
I have set up my neato vacuum,google home, nvidia shield, yale doorman lock and so on and have created some switches
Theese 2 works fine:
switch:
platform: template
switches:
yale_lock:
friendly_name: 'Entrance'
value_template: "{{ is_state('lock.entre', 'locked') }}"
turn_on:
service: lock.lock
entity_id: lock.entre
code: !secret house_pin
turn_off:
service: lock.unlock
switch:
platform: template
switches:
yale_alarm:
friendly_name: 'Larm'
value_template: "{{ is_state('alarm_control_panel.skivlingvagen_alarm', 'armed_away') }}"
turn_on:
service: alarm_control_panel.alarm_arm_away
entity_id: alarm_control_panel.skivlingvagen_alarm
code: !secret arm_pin
turn_off:
service: alarm_control_panel.alarm_disarm
But when i add this code for my zoneminder installation the second switch (the alarm switch) just disappears, config reports valid but i guess im doing something wrong.
Zoneminder switch code:
switch:
- platform: zoneminder
command_on: Modect
command_off: Monitor
Another question: is it possible to use the lock switch to arm/disarm the alarm with the same button? i cant get it working with automation, however i can get it working the other way around as in when arming alarm the door locks…
