I’m new to home automation and i hope iv put this into the right place
Iv been working on automating my house lighting with a raspberry pi running hassio with mosquitto node red and Alexa, working on 2 Arduino megas, one for the switch board and one for 20 relays. I also have 2 sonoff running just for testing which are working fine with hassio, node red and Alexa.
I am having a problem with hassio switching, for the Arduino’s
Hass will switch on the lights but will not switch the lights off.
Alexa turns on the lights but will not turn them off.
Node red turns lights on and off as it should.
The switch board turns the lights on and off ok.
Everything shows up in hassio overview as on and off ok.
As far as I can see the topics are all ok because in the mqtt, the momentary switches are working fine.
So, what do the logs say for home assistant after alexa turns off the lights? Basically you need to play ‘spot the difference’ when it turns off vrs not and then fix that.
