I am struggling with some automations, and to be more precise I want to switch on two outputs at a given time, let’s say at 20:00:00. To make a long story short, as I have tested many options:
1.I have two automations one switching output 1, another switching output 2 and both use the same trigger: time at 20:00:00, both of the automations are fired but only one output is switched on.
2. If I make the same two automations to be triggered one at 20:00:00 and the other at 20:00:10 then both outputs are getting switched on
3. For testing purpose I put both actions in one automation, to be triggered at the same time. Unfortunately, also here only one output is switched on.
Thanks Jonah1970 and jivesinger. There are no errors in the log, just information that automation is running and executing the steps:
2020-10-18 19:38:00 INFO (MainThread) [homeassistant.components.automation.lights_driveway] lights_driveway: Running automation actions
2020-10-18 19:38:00 INFO (MainThread) [homeassistant.components.automation.lights_driveway] lights_driveway: Executing step call service
The outputs are connected through Satel integration (module IORS). All automations I have are working fine, unless they are executed at exactly the same time like in the example above. To do a workaround I can offset them 10s, but I was just curious what is the problem that I cannot switch both of them at the same time.
Strange!I don’t have any other integrations with outputs to check. Anyway, I added slight delay and it works now, so I think we can close this subject.
