Hello all
First of all, it is a pleasure to be part of this forum.
I’m new in the HA world and thus, I’m facing some problems.
I have HA running on a RasPi 4. The installation and configuration run without problem. After that, I would like to access to HA remotely (from Internet outside of the local LAN). As soon as I understood, there are 2 possibilities: One possibility is with Nabu Casa by paying a monthly fee. The other option is with DuckDNS. I decided to use DuckDNS.
I have followed all the steps described en the doc:
- I have installed the DuckDNS
- I have created a domain.
- I have modified the config file of DuckDNS as follow:
“lets_encrypt”: {
“accept_terms”: true,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
“token”: “mytoken”,
“domains”: [
“mydomain.duckdns.org”
“seconds”: 300
} - I have modified the configuration.yaml and it looks like as follow:
´# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
´# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: https://mydomain.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
´# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
- I have “opened” the port 80 and 8123 (IPv4 and IPv6) for hassio in my FritzBox router.
Once this is done, I cannot access with my iPhone using the HA App when I’m outside of the local LAN.
Additionally, every time with I reboot Hassio I got the following error:
2019-12-29 18:03:17 ERROR (MainThread) [homeassistant.setup] Setup failed for base_url: Integration not found.
2019-12-29 18:03:17 ERROR (MainThread) [homeassistant.setup] Setup failed for ssl_key: Integration not found.
2019-12-29 18:03:17 ERROR (MainThread) [homeassistant.setup] Setup failed for ssl_certificate: Integration not found.
I’m lost and I really don’t know how to solve this issue. Can someone help me?
Thanks!
