There is a problem with orcon vent system, whenever I turned it on it goes for 15 mins and goes off after it.
Hard to say, what are you using to integrate it? a built in add-on or something custom?
Without information, I would suspect some sort of default runtime timer.
It says the inlet temperature is less than 5 degree but the temperature is definitely above that for sure
Does this have anything to do with Home Assistant?
