Problem with the setup of PWM LED
Unfortunately I cannot use the PWM LED component as I always get the following error:
  File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
    result = coro.throw(exc)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/core.py", line 1015, in _event_to_service_call
    yield from service_handler.func(service_call)
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/light/__init__.py", line 248, in async_handle_light_service
    yield from light.async_turn_on(**params)
  File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
    value = future.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/light/rpi_gpio_pwm.py", line 145, in turn_on
    brightness=_from_hass_brightness(self._brightness))
  File "/home/homeassistant/.homeassistant/deps/pwmled/led/__init__.py", line 66, in set
    self._update_pwm()
  File "/home/homeassistant/.homeassistant/deps/pwmled/led/__init__.py", line 75, in _update_pwm
    self._driver.set_pwm(values)
  File "/home/homeassistant/.homeassistant/deps/pwmled/driver/__init__.py", line 56, in set_pwm
    self._set_pwm(self._to_raw_pwm(values))
  File "/home/homeassistant/.homeassistant/deps/pwmled/driver/gpio.py", line 30, in _set_pwm
    self._pi.set_PWM_dutycycle(self._pins[i], raw_values[i])
  File "/home/homeassistant/.homeassistant/deps/pigpio.py", line 1396, in set_PWM_dutycycle
    self.sl, _PI_CMD_PWM, user_gpio, int(dutycycle)))
  File "/home/homeassistant/.homeassistant/deps/pigpio.py", line 977, in _pigpio_command
    sl.s.send(struct.pack('IIII', cmd, p1, p2, 0))
AttributeError: 'NoneType' object has no attribute 'send'
Please help me!
The pigpio-daemon needs to be running. You can start it with sudo pigpiod.
Thank you! That solved the problem!
Any idea how to start pigpio in HassOS or HassIO?
Anything new regarding HassOS?
