I have three of the 3RTHS24BZ Temp/Humidity Sensors It seems that they take up to an hour to send temp or humidty updates. They all connected to MQTT just fine. Looking at the Debug info in mqtt I am getting the same info from the sensor. Its as if it isn’t updating itself, the display shows correct info.
did I miss a setup on the sensor?
IIRC, those sensors update slowly (to conserve battery) and only report more frequently on actual temp or humidity changes. I believe you can change that in Z2M’s device reporting tab and increase the reporting interval (I think it defaults to 3600).
I have several of those and they update very well in my experience, but I’m only expecting changes when there is a change in temperature or humidity. For instance, I keep one in my grow tent and I can see instant humidity and temp changes in fairly real time when I turn on the humidifier or the heater.
