I had been using the Trend sensor successfully for a while but it has now broken (possibly when updating to 0.82) with the following in the log file:
2018-11-17 16:39:21 ERROR (Thread-11) [homeassistant.util.package] Unable to install package numpy==1.15.3: Failed building wheel for numpy
Failed cleaning build dir for numpy
locationsharinglib 1.2.1 has requirement requests==2.18.4, but you'll have requests 2.20.0 which is incompatible.
Command "/srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-srjsysos/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-l1dvrdld/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.5/numpy" failed with error code 1 in /tmp/pip-install-srjsysos/numpy/
You are using pip version 10.0.1, however version 18.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
2018-11-17 16:39:21 ERROR (MainThread) [homeassistant.requirements] Not initializing binary_sensor.trend because could not install requirement numpy==1.15.3
This was a manual installation on a Raspberry Pi 2 in a Python virtual environment. Any suggestions on how I can get this working again?
Edit: I’ve been able to get it working again by manually installing numpy version 1.15.3 using the command pip3 install numpy==1.15.3
from the virtual environment, but I don’t understand why Home Assistant failed to do this.
