Hi
I upgrade to new Tuya integration from this point all Tuya component don’t working.
I connect to Iot Tuya site made project everything fine but the integration in red and show problem like this:
Logger: homeassistant.components.tuya
Source: components/tuya/init.py:95
Integration: Tuya (documentation, issues)
First occurred: 05:17:09 (2 occurrences)
Last logged: 22:15:12
Tuya login error response: {‘code’: 2007, ‘msg’: ‘your ip(79.177.53.4) cross-region access is not allowed’, ‘success’: False, ‘t’: 1634177828848}
Tuya login error response: {‘code’: 2007, ‘msg’: ‘your ip(79.177.53.4) cross-region access is not allowed’, ‘success’: False, ‘t’: 1634238911957}
There is a warning in the setup process somewhere that your IP address needs to come from the same region as your selected data center is in.
You might want to/have to set up your Tuya/Smart Life and/or your ‘developer’ account at https://iot.tuya.com/ in the same region as your IP address.
Having the same issue, everything was working fine, all my 19 devices were showing up and working perfectly under the new Tuya integration. then all of sudden.
I can only see 1 device. rest not showing up.
even though i can still see ALL on my smartlife/Tuya app… only one shows up.
very frustrating.
thanks
only china data center can connect.
my country in the list to central europe data center strange !
in the project i see all component when i connect to china data center.
my ip isnt recognized in china.
After fiddeling around with the new Integration an finally got it not working with a permission error, i decided to drop all my tuya stuff. It is a way to complicated and i really do not like to have such an overblown IOT Dev account with an trial status. In consequence i also wrote an email to tuya techsupport to delete the account and all my data there. I am now really feed up with this tuya stuff.
1.I create another account in tuya app
2.I create new account iot tuya site
3.Create a new cloud project and link my app (with barcode)
4.all components shown and i control them from site.
5.new tuya integration install.
6.i write all details and now my error is: Login error (2406): skill id invalid
7.i dont undetstand what worng ?
→ Anmeldefehler (2007): your ip() cross-region access is not allowed
App Account → China (it is not possible to change region here)
Tuya Account → China
Scan was successfull.
The only way to fix that is to create new tuya platform account and new tuya app account with other region and add the devices one more time.
This is not good but a “workaroudn”.
I have the strange situation that my app shows UK and IOT can only connect to the app if i chose chinse datacentre.
So what should i do login the app with another email and change the location to china?
