Goodmorning to everyone
I’m having the followign issue on Windows 10 SO:
I have installed HA many months ago and set to start as service via NSSM without any problem.
Today I have upgraded it via pip3, and i have discovered that if windows lunch the server as service the core of HA is the previus versione 0.117.5 and use the following folder for config:
C:\Windows\System32\config\systemprofile\AppData\Roaming.homeassistant
If i use console and execute the hass.exe from the exactly same folder used in the service it start correctly the 2021.1.4 and use the following folder for config:
C:\Users\(user)\AppData\Roaming.homeassistant
I have manually copied .homeassistant folder from the first to the second one and it work like a charme, but i don’t want to open HA manually and i cannot figured it out where the issue is…
The Start folder in NSSM is “C:\Users\(user)\AppData\Roaming.homeassistant”
Any suggestion?
