Problem with video in notify
I want to attach a video in a message. I use this code to create a video when the front door opens and the alarm is on.
  - service: camera.record
      entity_id: "camera.grovkok"
      filename: '/media/cctv_grovkok/video.mp4'
      duration: 30
That works perfect and I get a video then I trigger it. Then I use this code to send the video to my android phone. I have a delay so the video will stored.
  - delay:
      seconds: 59
  - service: notify.mobile_app_pixel_6_pro
      message: Någon kom in
        url: "/lovelace/camera"
        priority: high
        video: '/media/local/cctv_grovkok/video.mp4'
I get the message but no video. If I convert the video on the internet and put I back in the same folder and trigger the automation I get the video in the message. Whats the problem? Can anyone help me?
what format are you converting it to?
From mp4 to mp4
sounds like HA core is not making the format android friendly, do you see any errors in the companion app logs?
04-10 18:22:55.647 10826 10826 D MessagingService: Found 0 frames for video notification
04-10 18:22:55.650 10826 10826 D MessagingService: Show notification with tag "null" and id "1811561647"
@dshokouhi
thats your issue, the format is not valid for the app as it cannot find a frame. When you converted the video did you leave it in teh same folder?
I get that error when I try to send a video that has been created in home assistant with the code above. Then I use the file (same video) that I have converted from mp4 to mp4 the logg says this.
04-10 18:47:57.030 10826 10826 D MessagingService: Found 19 frames for video notification
04-10 18:47:57.064 10826 10826 D MessagingService: Show notification with tag "null" and id "1812946270"
And the video is attached with the message.
The video is in the same folder in both case.
@dshokouhi
can you please file a bug in the android repo detailing everything here please?
please make sure to add back the issue template with all requested information
Fixed it, thanks
