i have just started exploring possibilites of node red.
I’m using node red addon version 3.1.1 in hassio 0.92
I would like to turn my water heater off in the evening, but only if it’s not heating water, then wait for some time and finally shut down the power socket. Turn it on again in the morning.
I have this flow
[{"id":"741b909d.b6c8d","type":"tab","label":"TUV test","disabled":true,"info":""},{"id":"cb248321.02fa2","type":"timeswitch","z":"741b909d.b6c8d","name":"","mytopic":"","lat":"","lon":"","starttime":"480","endtime":"1140","duskoff":"0","dawnoff":"0","sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"x":120,"y":200,"wires":[["2774a6c2.8a26ba"]]},{"id":"2774a6c2.8a26ba","type":"switch","z":"741b909d.b6c8d","name":"check on/off","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":290,"y":200,"wires":[["fcec32cc.e11ab"],["2b64cb4a.a6dd64"]]},{"id":"cbb5da.37007a28","type":"api-call-service","z":"741b909d.b6c8d","name":"","server":"dcf02f05.b9371","service_domain":"switch","service":"turn_on","data":"{\"entity_id\":\"switch.neo_coolcam_unknown_type_0200_id_1027_switch\"}","mergecontext":"","output_location":"","output_location_type":"none","x":770,"y":100,"wires":[[]]},{"id":"2bd9ac19.a18004","type":"api-call-service","z":"741b909d.b6c8d","name":"","server":"dcf02f05.b9371","service_domain":"notify","service":"jabber_libor","data":"{\"message\":\"zapnuto TUV\"}","mergecontext":"","output_location":"","output_location_type":"none","x":780,"y":160,"wires":[[]]},{"id":"e9e2e385.f7fca","type":"api-call-service","z":"741b909d.b6c8d","name":"","server":"dcf02f05.b9371","service_domain":"switch","service":"turn_off","data":"{\"entity_id\":\"switch.neo_coolcam_unknown_type_0200_id_1027_switch\"}","mergecontext":"","output_location":"","output_location_type":"none","x":1110,"y":220,"wires":[[]]},{"id":"73619f63.42021","type":"api-call-service","z":"741b909d.b6c8d","name":"","server":"dcf02f05.b9371","service_domain":"notify","service":"jabber_libor","data":"{\"message\":\"vypnuto TUV\"}","mergecontext":"","output_location":"","output_location_type":"none","x":1120,"y":280,"wires":[[]]},{"id":"fcec32cc.e11ab","type":"api-current-state","z":"741b909d.b6c8d","name":"is on?","server":"dcf02f05.b9371","outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"switch.neo_coolcam_unknown_type_0200_id_1027_switch","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":450,"y":160,"wires":[["cbb5da.37007a28","2bd9ac19.a18004"],[]]},{"id":"2b64cb4a.a6dd64","type":"api-current-state","z":"741b909d.b6c8d","name":"is off?","server":"dcf02f05.b9371","outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"switch.neo_coolcam_unknown_type_0200_id_1027_switch","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":450,"y":280,"wires":[["10f7bae.0ec4445","3f108c99.cad3b4"],[]]},{"id":"10f7bae.0ec4445","type":"api-call-service","z":"741b909d.b6c8d","name":"","server":"dcf02f05.b9371","service_domain":"notify","service":"jabber_libor","data":"{\"message\":\"waiting TUV\"}","mergecontext":"","output_location":"","output_location_type":"none","x":780,"y":340,"wires":[[]]},{"id":"2dfbb60f.f22bfa","type":"stoptimer","z":"741b909d.b6c8d","duration":"10","units":"Second","payloadtype":"num","payloadval":"0","name":"","x":870,"y":240,"wires":[["e9e2e385.f7fca","73619f63.42021"],[]]},{"id":"3f108c99.cad3b4","type":"ha-wait-until","z":"741b909d.b6c8d","name":"","server":"dcf02f05.b9371","outputs":2,"entityId":"sensor.neo_coolcam_unknown_type_0200_id_1027_power","property":"","comparator":"lt","value":"200","valueType":"num","timeout":"3600","timeoutUnits":"seconds","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"x":640,"y":240,"wires":[["2dfbb60f.f22bfa"],[]]},{"id":"dcf02f05.b9371","type":"server","z":"","name":"Home Assistant"}]
But it was sitting there for an hour, waiting for timeout.
I guess, problem is, that value from sensor is of type text, not number?
I changed my flow, so it’s converted to number and stored to flow variable.
[{"id":"ba0a532c.12806","type":"tab","label":"TUV","disabled":false,"info":""},{"id":"f219a95.54c6d58","type":"timeswitch","z":"ba0a532c.12806","name":"","mytopic":"","lat":"","lon":"","starttime":"480","endtime":"1140","duskoff":"0","dawnoff":"0","sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"x":180,"y":240,"wires":[["62b6662f.da9358"]]},{"id":"62b6662f.da9358","type":"switch","z":"ba0a532c.12806","name":"check on/off","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","repair":false,"outputs":2,"x":350,"y":240,"wires":[["4b57b258.f95f6c"],["1cb97de6.7a4882"]]},{"id":"bd66f33.4f4951","type":"api-call-service","z":"ba0a532c.12806","name":"","server":"dcf02f05.b9371","service_domain":"switch","service":"turn_on","data":"{\"entity_id\":\"switch.neo_coolcam_unknown_type_0200_id_1027_switch\"}","mergecontext":"","output_location":"","output_location_type":"none","x":830,"y":140,"wires":[[]]},{"id":"65c17f6b.01627","type":"api-call-service","z":"ba0a532c.12806","name":"","server":"dcf02f05.b9371","service_domain":"notify","service":"jabber_libor","data":"{\"message\":\"zapnuto TUV\"}","mergecontext":"","output_location":"","output_location_type":"none","x":840,"y":200,"wires":[[]]},{"id":"54c05678.607df8","type":"api-call-service","z":"ba0a532c.12806","name":"","server":"dcf02f05.b9371","service_domain":"switch","service":"turn_off","data":"{\"entity_id\":\"switch.neo_coolcam_unknown_type_0200_id_1027_switch\"}","mergecontext":"","output_location":"","output_location_type":"none","x":1170,"y":260,"wires":[[]]},{"id":"4aeb328b.37eadc","type":"api-call-service","z":"ba0a532c.12806","name":"","server":"dcf02f05.b9371","service_domain":"notify","service":"jabber_libor","data":"{\"message\":\"vypnuto TUV\"}","mergecontext":"","output_location":"","output_location_type":"none","x":1180,"y":320,"wires":[[]]},{"id":"4b57b258.f95f6c","type":"api-current-state","z":"ba0a532c.12806","name":"is on?","server":"dcf02f05.b9371","outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"switch.neo_coolcam_unknown_type_0200_id_1027_switch","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":510,"y":200,"wires":[["bd66f33.4f4951","65c17f6b.01627"],[]]},{"id":"1cb97de6.7a4882","type":"api-current-state","z":"ba0a532c.12806","name":"is off?","server":"dcf02f05.b9371","outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"switch.neo_coolcam_unknown_type_0200_id_1027_switch","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":510,"y":320,"wires":[["eb3823d5.24865","3b40076.c9a49f8"],[]]},{"id":"eb3823d5.24865","type":"api-call-service","z":"ba0a532c.12806","name":"","server":"dcf02f05.b9371","service_domain":"notify","service":"jabber_libor","data":"{\"message\":\"waiting TUV\"}","mergecontext":"","output_location":"","output_location_type":"none","x":840,"y":380,"wires":[[]]},{"id":"aaa9dee8.6f991","type":"stoptimer","z":"ba0a532c.12806","duration":"10","units":"Second","payloadtype":"num","payloadval":"0","name":"","x":930,"y":280,"wires":[["54c05678.607df8","4aeb328b.37eadc"],[]]},{"id":"cc3b7f5a.2c55","type":"function","z":"ba0a532c.12806","name":"toNum","func":"msg.payload = Number(msg.payload);\nreturn msg;","outputs":1,"noerr":0,"x":740,"y":560,"wires":[["913d1598.77dbe8","5daa0ffe.1b2bd"]]},{"id":"913d1598.77dbe8","type":"change","z":"ba0a532c.12806","name":"","rules":[{"t":"set","p":"powerState","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":970,"y":560,"wires":[[]]},{"id":"3b40076.c9a49f8","type":"switch","z":"ba0a532c.12806","name":"check flow.powerState","property":"powerState","propertyType":"flow","rules":[{"t":"lt","v":"200","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":700,"y":280,"wires":[["aaa9dee8.6f991"]]},{"id":"5daa0ffe.1b2bd","type":"debug","z":"ba0a532c.12806","name":"","active":true,"tosidebar":true,"console":true,"tostatus":false,"complete":"payload","targetType":"msg","x":960,"y":620,"wires":[]},{"id":"902766b9.c3b138","type":"server-state-changed","z":"ba0a532c.12806","name":"","server":"dcf02f05.b9371","entityidfilter":"sensor.neo_coolcam_unknown_type_0200_id_1027_power","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"x":340,"y":560,"wires":[["cc3b7f5a.2c55","5daa0ffe.1b2bd"]]},{"id":"dcf02f05.b9371","type":"server","z":"","name":"Home Assistant"}]
This works ok, but i would like to use first version, if possible.
Is the first flow correct and problem is only in text versus number value?
Thanks,
Libor
