I have the following wake on LAN configuration. It is only working if I comment out the #host parameter. If the #host is in the config, it does not wake up my computer. If not there it wakes up, but I do not see the status nor can I turn off the computer (turn off part is not yet configured, planning to do it in a few days). Does anyone else have the same problem? Any idea what should I try? Thanks in advance!
Just pushing up this problem, but it’s look there is a problem (maybe it’s a bug that need to be reported) with the service “wake_on_lan.send_magic_packet” : because if you try to use it by “call-service” action you can’t specify the host parameter that is not exposed.
The temporary solution is to declare the switch in the configuration yaml directly with the wake_on_lan … not really usefull, need to be done for each device, but it’s working …
6 years later?
I guarantee you it is not the same problem, there may not be any of the same code in the code base that old for this function…
Please post a new message OR if you think it’s a code problem, post an issue.
Remember if something works but does not work the way you like, it is generally NOT a bug, but rather a Feature Request and in that case should NOT be written up as an issue. There is another thread for [FR] here. Feature Requests - Home Assistant Community.
