I just bought the Waveshare ESP32-S3-Touch-LCD-5 1024-600 and I success in the installation from the ESPhome but I can’t see in my display the circles and other drawing that I code with the lambda function.
I just see the display with some sort of noise all in the bottom of it (from left to right).
Do you have any suggestions?
This is how my code look like right now:
esphome:
friendly_name: Meter Display
platformio_options:
build_flags: "-DBOARD_HAS_PSRAM"
board_build.esp-idf.memory_type: qio_opi
board_build.flash_mode: dio
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
sdkconfig_options:
CONFIG_FREERTOS_HZ: "1000"
CONFIG_ESP_DEFAULT_CPU_FREQ_MHZ_240: y
CONFIG_SPIRAM_SPEED_120M: y
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
CONFIG_ESP32S3_DATA_CACHE_64KB: y
CONFIG_COMPILER_OPTIMIZATION_PERF: y
logger:
api:
encryption:
key: "cm7vOJaVoc/h3lMyOonw7o/IW9wBEM4UQLGCiX0pHII="
ota:
- platform: esphome
password: "a434ab3e87f61f9de38aa7f85f9e494c"
wifi:
ssid: !secret wifi_ssid
psram:
mode: octal
speed: 80MHz
i2c:
sda: GPIO8
scl: GPIO9
scan: true
touchscreen:
platform: gt911
interrupt_pin: GPIO4
display:
- platform: rpi_dpi_rgb
auto_clear_enabled: false
color_order: RGB
update_interval: never
pclk_frequency: 16MHz
dimensions:
width: 1024
height: 600
de_pin:
number: 5
hsync_pin:
number: 46
ignore_strapping_warning: true
vsync_pin:
number: 3
pclk_pin: 7
hsync_back_porch: 30
hsync_front_porch: 210
hsync_pulse_width: 30
vsync_back_porch: 4
vsync_front_porch: 4
vsync_pulse_width: 4
data_pins:
red:
- 1 #r3
- 2 #r4
- 42 #r5
- 41 #r6
- 40 #r7
blue:
- 14 #b3
- 38 #b4
- 18 #b5
- 17 #b6
- 10 #b7
green:
- 39 #g2
- 0 #g3
- 45 #g4
- 48 #g5
- 47 #g6
- 21 #g7
lambda: |-
auto red = Color(255, 0, 0);
auto green = Color(0, 255, 0);
auto blue = Color(0, 0, 255);
auto white = Color(255, 255, 255);
id(main_display).filled_circle(50, 50, 40, red);
id(main_display).filled_circle(100, 50, 40, green);
id(main_display).filled_circle(150, 50, 40, blue);
id(main_display).filled_circle(200, 50, 40, white);
it.line(0, 0, 100, 50);
it.rectangle(5, 20, 30, 42);
it.filled_rectangle(40, 40, 30, 42);
it.circle(20, 40, 10);
it.filled_circle(20, 75, 10);
it.triangle(25, 5, 100, 5, 80, 25);
it.filled_triangle(115, 5, 95, 25, 125, 70);
it.filled_regular_polygon(170, 45, 20, EDGES_HEXAGON);
it.regular_polygon(170, 45, 40, EDGES_OCTAGON, VARIATION_FLAT_TOP);
Thank You very much in advance for all of your support.
Regards
Matteo
