Hi. I’m not completely sure if this is related to esphome or influxdb or grafana, but I’ll give it a go here anyway. I’m having an esp32 connected to capacitive soil sensor. I have that setup on esphome on home assistant and it is supposed to safe the information on influxdb and then I’d make graphs of it using grafana. But even though my esphome log shows values that makes sense, my influxdb and grafana shows values all over the place. I have my yaml-code, esphome log and photo of influxdb next. Any help is appreciated! Thank tou everyone in advance.
esphome:
platform: ESP32
board: esp32doit-devkit-v1
on_boot:
then:
lambda: |-
id(output_v).turn_on();
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "fabc905d74b9700399b6b8777dbd90f0"
wifi:
ssid: "TP-Link_6988"
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.0.120
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.0.1
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
ap:
ssid: "Soil-Sensor Fallback Hotspot"
password: "wipg5GNdiXyA"
captive_portal:
- platform: adc
pin: 36
name: "Soil moisture"
attenuation: 2.5db
unit_of_measurement: "%"
filters:
- sliding_window_moving_average:
window_size: 10
send_every: 10
- calibrate_linear:
- 0.80 -> 0.0
- 0.30 -> 100.0
- throttle: 5s
- heartbeat: 1min
# force_update: true
output:
platform: gpio
pin: 32
