Problem with writing values to Google Sheets
I followed a post from this: Writting sensors' values to Google Sheets to write values to Google Sheets.
This is my AppDaemon config:
system_packages: []
python_packages:
  - hass-apps
  - gspread
  - oauth2client
init_commands: []
This is in my apps.yaml
google_sheets:
  module: gsheets
  class: GSheets
And this is my gsheets.py
import appdaemon.plugins.hass.hassapi as hass
import gspread
from oauth2client.service_account import ServiceAccountCredentials
import datetime
class GSheets(hass.Hass):
  def initialize(self):
     self.log("GSheets started")
     runtime = datetime.datetime.now()
     addseconds = (round((runtime.minute*60 + runtime.second)/300)+1)*300
     runtime = runtime.replace(minute=0, second=0, microsecond=0) + datetime.timedelta(seconds=addseconds)
     self.run_every(self.publish_to_gs,runtime,300)
  def publish_to_gs(self,kwargs):
     scope = ['https://spreadsheets.google.com/feeds',
              'https://www.googleapis.com/auth/drive']
     creds = ServiceAccountCredentials.from_json_keyfile_name('/share/googleDriveCredentials.json', scope)
     client = gspread.authorize(creds)
     fmt = '%Y-%m-%d %H:%M:%S'
     d = datetime.datetime.now()
     d_string = d.strftime(fmt)
     state_temp = self.get_state("sensor.solar_power_current")
     state_humi = self.get_state("sensor.solar_power_today")
     sheet = client.open("data").sheet1
     row = [d_string,state_temp,state_humi]
     index = 6
     sheet.insert_row(row, index, value_input_option='USER_ENTERED')
And this is what the log shows:
2020-05-06 17:48:23.860971 WARNING google_sheets: ------------------------------------------------------------
2020-05-06 17:48:23.862311 WARNING google_sheets: Unexpected error initializing app: google_sheets:
2020-05-06 17:48:23.863667 WARNING google_sheets: ------------------------------------------------------------
2020-05-06 17:48:23.871420 WARNING google_sheets: Traceback (most recent call last):
  File "/usr/lib/python3.8/site-packages/appdaemon/app_management.py", line 820, in check_app_updates
    await self.init_object(app)
  File "/usr/lib/python3.8/site-packages/appdaemon/app_management.py", line 271, in init_object
    modname = await utils.run_in_executor(self, __import__, app_args["module"])
  File "/usr/lib/python3.8/site-packages/appdaemon/utils.py", line 276, in run_in_executor
    response = future.result()
  File "/usr/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/config/appdaemon/apps/gsheets.py", line 2, in <module>
    import gspread
ModuleNotFoundError: No module named 'gspread'
2020-05-06 17:48:23.874022 WARNING google_sheets: ------------------------------------------------------------
So I think it misses the gspread module. I am on Hassio, so how do I enable it?
Did you restart the add-on after adding the packages to the AppDaemon config?
