Today my yeelight not work correctly
I have this problem
dic 18 10:37:48 sdomotica Home Assistant[12267]: 2022-12-18 10:37:48.796 DEBUG (MainThread) [homeassistant.components.yeelight.scanner] Yeelight scanning
dic 18 10:37:48 sdomotica Home Assistant[12267]: 2022-12-18 10:37:48.824 DEBUG (MainThread) [homeassistant.components.yeelight.scanner] Discovered via SSDP: {‘Cache-Control’: ‘max-age=3600’, ‘Date’: ‘’, ‘Ext’: ‘’, ‘Location’: ‘yeelight://192.168.0.63:55443’, ‘Server’: ‘POSIX UPnP/1.0 YGLC/1’, ‘id’: ‘0x00000000035b751b’, ‘model’: ‘color’, ‘fw_ver’: ‘76’, ‘support’: ‘get_prop set_default set_power toggle set_bright start_cf stop_cf set_scene cron_add cron_get cron_del set_ct_abx set_rgb set_hsv set_adjust adjust_bright adjust_ct adjust_color set_music set_name’, ‘power’: ‘on’, ‘bright’: ‘7’, ‘color_mode’: ‘3’, ‘ct’: ‘2659’, ‘rgb’: ‘16743168’, ‘hue’: ‘29’, ‘sat’: ‘100’, ‘name’: ‘’, ‘_timestamp’: datetime.datetime(2022, 12, 18, 10, 37, 48, 823656), ‘_host’: ‘192.168.0.63’, ‘_port’: 49156, ‘_local_addr’: (‘0.0.0.0’, 41415), ‘_remote_addr’: (‘192.168.0.63’, 49156), ‘_location_original’: ‘yeelight://192.168.0.63:55443’, ‘location’: ‘yeelight://192.168.0.63:55443’, ‘_source’: <SsdpSource.SEARCH: ‘search’>}
dic 18 10:37:48 sdomotica Home Assistant[12267]: 2022-12-18 10:37:48.825 DEBUG (MainThread) [homeassistant.components.yeelight.scanner] Discovered via SSDP: {‘Cache-Control’: ‘max-age=3600’, ‘Date’: ‘’, ‘Ext’: ‘’, ‘Location’: ‘yeelight://192.168.0.63:55443’, ‘Server’: ‘POSIX UPnP/1.0 YGLC/1’, ‘id’: ‘0x00000000035b751b’, ‘model’: ‘color’, ‘fw_ver’: ‘76’, ‘support’: ‘get_prop set_default set_power toggle set_bright start_cf stop_cf set_scene cron_add cron_get cron_del set_ct_abx set_rgb set_hsv set_adjust adjust_bright adjust_ct adjust_color set_music set_name’, ‘power’: ‘on’, ‘bright’: ‘7’, ‘color_mode’: ‘3’, ‘ct’: ‘2659’, ‘rgb’: ‘16743168’, ‘hue’: ‘29’, ‘sat’: ‘100’, ‘name’: ‘’, ‘_timestamp’: datetime.datetime(2022, 12, 18, 10, 37, 48, 825201), ‘_host’: ‘192.168.0.63’, ‘_port’: 49156, ‘_local_addr’: (‘0.0.0.0’, 41415), ‘_remote_addr’: (‘192.168.0.63’, 49156), ‘_location_original’: ‘yeelight://192.168.0.63:55443’, ‘location’: ‘yeelight://192.168.0.63:55443’, ‘_source’: <SsdpSource.SEARCH: ‘search’>}
dic 18 10:38:01 sdomotica Home Assistant[12267]: 2022-12-18 10:38:01.856 DEBUG (MainThread) [homeassistant.components.yeelight.device] timed out while trying to update device 192.168.0.63, None:
dic 18 10:38:01 sdomotica Home Assistant[12267]: 2022-12-18 10:38:01.857 DEBUG (MainThread) [homeassistant.components.yeelight] Shutting down Yeelight Listener (unload)
dic 18 10:38:01 sdomotica Home Assistant[12267]: 2022-12-18 10:38:01.858 DEBUG (MainThread) [homeassistant.components.yeelight.device] Unable to update device 192.168.0.63, None: The write socket is closed
dic 18 10:38:11 sdomotica Home Assistant[12267]: 2022-12-18 10:38:11.868 DEBUG (MainThread) [homeassistant.components.yeelight.device] Received callback: {‘connected’: True}
dic 18 10:38:11 sdomotica Home Assistant[12267]: 2022-12-18 10:38:11.873 DEBUG (MainThread) [homeassistant.components.yeelight.device] Received callback: {‘connected’: False}
dic 18 10:38:11 sdomotica Home Assistant[12267]: 2022-12-18 10:38:11.882 DEBUG (MainThread) [homeassistant.components.yeelight.device] Received callback: {‘connected’: True}
dic 18 10:38:11 sdomotica Home Assistant[12267]: 2022-12-18 10:38:11.899 DEBUG (MainThread) [homeassistant.components.yeelight.device] Received callback: {‘connected’: False}
dic 18 10:38:26 sdomotica Home Assistant[12267]: 2022-12-18 10:38:26.872 DEBUG (MainThread) [homeassistant.components.yeelight.device] timed out while trying to update device 192.168.0.63, None:
dic 18 10:38:26 sdomotica Home Assistant[12267]: 2022-12-18 10:38:26.873 DEBUG (MainThread) [homeassistant.components.yeelight] Shutting down Yeelight Listener (unload)
dic 18 10:38:26 sdomotica Home Assistant[12267]: 2022-12-18 10:38:26.875 DEBUG (MainThread) [homeassistant.components.yeelight.device] Unable to update device 192.168.0.63, None: The write socket is closed
