hello, after the last update 0.116.1 i have issue with the yeelight bulb, here what is in the log:
2020-10-08 22:49:45 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Luce Camera for light
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 231, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 287, in async_setup_entry
return await hass.data[DOMAIN].async_setup_entry(entry)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 140, in async_setup_entry
platform = await async_prepare_setup_platform(
File "/usr/src/homeassistant/homeassistant/setup.py", line 298, in async_prepare_setup_platform
platform = integration.get_platform(domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 401, in get_platform
cache[full_name] = importlib.import_module(
File "/usr/local/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/usr/src/homeassistant/homeassistant/components/yeelight/light.py", line 140, in <module>
EFFECT_RANDOM_LOOP: yee_transitions.randomloop,
AttributeError: module 'yeelight.transitions' has no attribute 'randomloop'
i’m using HA in Container
how can i fix it ?
the configuration is:
yeelight:
devices:
192.168.1.X:
192.168.1.X:
192.168.1.X:
